Latest post 05-17-2009 11:40 AM by Doc. 2 replies.
Page 1 of 1 (3 items)
  • 05-17-2009 6:49 AM
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Difference between SW 5.08a and 5.02a
    Is there a difference between SW 5.02a (which I have) and 5.08a ? And if so, what difference is there / which issue's should 5.08a solve?
    (it's the SW of a BV7-40 mkIII)
  • 05-17-2009 7:09 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Difference between SW 5.08a and 5.02a
    Keith Saunders:
    The following problems are fixed with software version 5.08:-
    • TV switches off, if two-way IR products are used in the same room.
    • Speaker mode changes when changing channel, seen on DVB-HD and external STB
    • Clicking noise from centre/front speaker when changing channel on an external set-top box connected by HDMI/SPDIF, after updating to software version 5.02
    • No video on built-in DVD after software update 5.02 (US version only)
    • Not possible to change Region code on DVD
    • Switching to built-in DVB-T/S picture format is locked to format 3, until the next time the channel is changed.
    • From standby, picture format from internal DVB module cannot be changed. Locked to last shown format from before standby.
    • If DVD loader is opened twice in standby, it might take up to three attempts to play a DVD when selected
    • STB connected via HDMI is not always switched off.
    • STB connected with HDMI and SCART/CVBS cannot be controlled in a link room if main room TV is switched off
    • Error message with SKY HD box in link room, if main room TV is switched off
    Quim
  • 05-17-2009 11:40 AM In reply to
    • Doc
    • Posts 585
    Thanks Quim!
