Latest post 05-17-2009 6:58 PM by birgerbum. 3 replies.
Page 1 of 1 (4 items)
  • 05-16-2009 7:46 PM
    • wind
    • Not Ranked
    • Joined on 05-17-2009
    • Posts 6
    Beocenter 8500. Probleme CD
    Bonjour,
    Une solution pour changer ou reparer le CD sur un BC 8500?
    Je mets le cd, il tourne un peu et s'arrete et rien ne se passe.
    La partie cellule semble "libre" est ce normal?
    Merci
  • 05-17-2009 4:35 PM In reply to
    Re: Beocenter 8500. Probleme CD
    HI wind
    I know you are french but could you possible write in in English I cannot speak the french language.I know what your problem is
    regards
    jan
  • 05-17-2009 4:47 PM In reply to
    • wind
    • Not Ranked
    • Posts 6
    I put the cd, it turns a little and stop. Nothing takes place.
    The part cell (unit) seems "free" it is normal?
    I hope you can understand me, thank you !
    Lionel
  • 05-17-2009 6:58 PM In reply to
    Hi Wind
    search the site for c2103 and there are explanations to your problem they are in english hope you understand.it`s the same for your bc8500
    regards
    jan
    vive la france
