Latest post 05-16-2009 1:48 AM by Cleviebaby. 4 replies.
Page 1 of 1 (5 items)
  • 05-15-2009 5:46 PM
    Headphone Pads replacement
    I have a pair of Form 2 (I think - the smaller rectangular ones) headphone and the small foam ear pads have completely fallen apart - B&O must use cheap foam since I hear foam rot to be a common problem with speakers.  Any ideas of where or how they can be replaced?  I live in the US and when I asked my dealer, I dont recall the exact amount, because I must have had a seizure and blocked from my memory when they told me how much replacements would cost.  (I am sure I could probably even make my own!)
    Although temped to buy a new pair of something better......
    -michael
  • 05-15-2009 7:09 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Headphone Pads replacement
    I seem to remember the replacement Form2 pads being not that expensive - about £12-15 ?
    If your dealer in the US quoted a silly amount, i'd be happy to order and post some to you at cost (they shouldn't cost much to post - a butterfly with it's underwear on weighs more...)
    Lee
  • 05-15-2009 7:23 PM In reply to
    As always, I appreciate your help.... but now I remember  12-15 pounds/dollars (whatever the conversion rate is these days) for a pair of foam covers for headphones?  Is B&O out of the freakin' mind - oh wait they are and that is why they are doing crappy lately.......
    -michael
  • 05-15-2009 7:46 PM In reply to
    What exactly can you get for 12-15 pounds these days? Around these parts, it would get you about 3-4 kg of ground beef. And that would definitely look silly around your ears.
    -mika
  • 05-16-2009 1:48 AM In reply to
    Michael,
    What have you been doing to them!
    My Form 2s are at least 10 years old, get used regularly and the foam is still immaculate.  I do wash the pads fairly frequently and dry them fully which might help.
    If you like the sound of the Form 2s, and I assume you do, then 15$ seems not unreasonable to continue to enjoy them.  Not sure you could buy better phones for that!
    Cleve
