1st March February 2012
Latest post 06-20-2009 8:06 AM by StUrrock. 19 replies.
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
Re: Is it possible to set up a BeoLink system without an B&O TV or Audio System ?
If the Apple laptop can run window, then you can use a Beolink PC 2 box as an audio master and distribute N.MUSIC and N.RADIO.
The Beolink PC 2 works with a Mac under Mac OS X as well, but cannot be used as an audio master.
TripEnglish
- Joined on 10-27-2007
- America
- Posts 1,595
No. The PC2/BeoPort is a client product to be used in conjunction with a BeoSound audio master. Even with a BeoVision product, a BeoSound is required to distribute N.MUSIC & N.RADIO out onto a link network.
However, if you want to use a Mac to drive a link network, AirTunes is a candidate.
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
elephant
- Melbourne, Australia
- Posts 2,215
TripEnglish:However, if you want to use a Mac to drive a link network, AirTunes is a candidate.
But, in that case, the music from the Mac is distributed wirelessly to the Airport Express and then via a wired connection to the (active) speakers or the amplifier -- that is, it is not going over B&O Master Link media nor over B&O wireless.
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
TripEnglish
- America
- Posts 1,595
True, but that's the point.
If he doesn't have a BeoSound, he probably doesn't have a link system.
Usually when someone enquires after options like this it is a budget issue. A BeoLink system, while superior in nearly every way, is very pricey. If he wants to use the Mac anyway, there is a way to "distribute" music without the link system but using (if he so chooses) our fine loudspeakers.
craigmcgowan
- Joined on 06-01-2009
- Posts 3
we have inherited a house which has beolink, and a whole bunch of ceiling mounted b&o speakers and wall mounted b&o remote control devices
however the original beosound 9000 has been removed by the previous owner :-( what we are looking for is a cost effective way of using the infrastructure with our existing hardware / multi media (pcs, macs and ipods)
Any advice would be much appreciated
PhilLondon
- London
- Posts 2,545
You need to verify that there is a Masterlink cable going around the house, or if it is an older MCL cabling.
I suppose it is a Masterlink because the user had a BS9000.
If that is the case, the good news is that you can connect you Beoport to any ML point anywhere in the house and here you go.
Note that the Beoport can only work as a master if connected to a computer running Windows, not Mac OS X.
Are there any IR eyes around your house. You should describe what you see and we can help more...
StUrrock
- Joined on 02-04-2008
- Cambridgeshire
- Posts 219
Hi Guys some superb suggestions and ideas above.
But let us just answer the specific question asked in this Thread:-)
Let us just clarify. BeoLink system?
What? Without an B&O TV or Audio System ?
The answer must be................ Wait for it............
Again let us listen to the question "BeoLink system without an B&O TV or Audio System ?"
The answer is............................................................................................ NO.
sorry couldn't help myself!!!
PhilLondon
- London
- Posts 2,545
StUrrock:The answer is............................................................................................ NO.
I disagree, a Beoport connected to a PC should do the trick. It can be set as an audio master and be used to distribute audio around the house without the need of Beosound or a Beovision.
StUrrock
- Cambridgeshire
- Posts 219
Hi PhilLondon,
As far as I know Beoport can distribute N.Music N.Radio but only when there is an audio master.
TripEnglish (as ever) sums it up perfectly;
"No. The PC2/BeoPort is a client product to be used in conjunction with a BeoSound audio master. Even with a BeoVision product, a BeoSound is required to distribute N.MUSIC & N.RADIO out onto a link network. "
Beleive me if I am wrong I will be so pleased......................
Thanks for your suggestion.
PhilLondon
- London
- Posts 2,545
I do not have a Beoport on hand to prove it, but here is an extract of the user guide:
Additional Options for the BeoPort box
In addition to Option number 6, it is possible to select Option numbers 0, 2 and 4. Option number 0 is for a setup where you want to disable an IR receiver. Option 2 is for a setup where you want to use your PC as a main room product. Option 4 is for a setup with link room products placed in the same room as the main system. The use for these Options is limited, but your retailer can be contacted for further information about Option number selection.
TripEnglish
- America
- Posts 1,595
Phil,
The product guide is unfortunately unclear. It is referring to a scenario wherein you want to connect an eye to it, and use it as though it is a stereo in a single room (say you have a couch in the study, for example), but it cannot distribute under that scenario.
The product guide is so unclear, in fact, and information regarding this so scarce internally, that I had to sell a BeoSound 4 at a significantly reduced price when I made the same mistake with a client and proposed a system with just a BeoPort!
saf
- Joined on 04-17-2007
- Posts 458
StUrrock:
Hi PhilLondon,
I'm actually 'somewhat' with PhilLondon and that one. Why, and why I say somewhat?
I had only Beolab 3500 and Beoport and it worked - in the same room with a PC. (Note there is only a Masterlink connection between BL3500 and the Beoport hardware.)
However, as BL3500 and Beoport were connected via MasterLink, ie no speakers connected to the Beoport via PowerLink, Beoport's on-screen controls were somewhat limited. Namely the sound controls, volume etc, because they are only related to speakers (or headphones) connected directly to Beoport via PowerLink (headphones output). But those functions (volume etc) were perfectly working via Beo4 - via Beolab 3500's IR sensor.
There were some more smaller issue as well though, such as the clock not showing the right time on BL3500 - as if, indeed, it only could get this info from a (missing) Beosound and not the computer...
Unfortunately, I stopped just one step short of being now able to confirm if the setup in question would work or not. I did not add a couple of eg Beolink Actives plus speakers plus IR eyes. Still, I can't see why it - in principle - should not work though?
That said, I agree with what's been suggested by Trip and others: though entirely B&O, it's most probably not the most elegant/functional/cost efficient solution.
craigmcgowan
- Posts 3
Hi there, we have what I believe to be passive controllers of some kind in a number of rooms throughout the house (circular wall mounted with play and volume controlls), cant tell what speakers as they are ceiling mounted, and the BS9000 was countersunk into a wall unit. but I Think there is some paper works somewhere in all the stuff we got with the house that might shed some light on what is there. I am away fro home at the moment but willl check when I get back. Happy to buy something to make use of the infrastructure just not another BS9000 or equivalent... especailly as 90% of current media is now either mp3 or or aac (spent quite some time creating music library of all our CD's ! We are not looking for an audiophile solution.. just piped music when in the bath or kitchen or bedroom.
Thanks for the suggestions to date (shame it seems such a difficult question to get a definitive answer to)
PhilLondon
- London
- Posts 2,545
I'll try and give you an answer after this week end.
I am visiting a friend who has a masterlinked home and a Beoport.
I'll disconnect his TV and Beosound and will try getting sound in his link rooms.
p.
PhilLondon
- London
- Posts 2,545
As promised I tested the configuration:
Beoport, in option2, connected to a PC and a Beolab2000 in another room.
Beovision and Beosound disconnected from the ML.
Result: It works perfectly, you can call N.MUSIC, N.RADIO and even CD (the PC's CD) with the Beo4 in the Beolab2000's room.
This picture show all the possible options. (Option 2 or 0 need to be used when no Audiomaster are present).
We also tested it on a Mac and it does NOT work under MacOSX, as you can only choose option 6 or 4.
A mac running windows in Bootcamp or VMWare works fine.
Hope that helped.
P.
Peter
- Joined on 02-12-2007
- Posts 9,572
Are you sure it was a Beosound 9000 or was it a Beocenter 9000? Makes a big difference. A picture of the plugs or the room controls would help. You do need a piece of B&O - if you have a Beosound 9000, then an Ouverture should be fine for some basic control - you can attach the Mac to the Aux socket and control iTunes using an iPod touch. If a Beocenter 9000, much the same but you need something like a Beomaster 5500 or a Beocenter 9000/9500.
craigmcgowan
- Posts 3
excellent thanks so much
for info it was definitely BEOSOUND 9000 that was there
still remaining are beovox1 ceiling mounted in 5 different rooms each with beolink passive and infrared eye / volume control
Hope this will still work as you suggested , will see if I can find a friendly B&O specialist that will lend us a Beoport to try
Many thanks for your help
PhilLondon
- London
- Posts 2,545
You can find some second had Beoport, often called by their old names "Beolink PC2" on ebay. They are identical, except for the firmware. The firmware can be updated. The important is to have the USB version.
Actually, there is one now on ebay UK.
Price new is 370 euro.
I confirm that you do not need a Beosound at all in the system, nor a TV to access Beoport from link room. Beoport can be set as an Audiomaster when connected to a computer running windows.
StUrrock
- Cambridgeshire
- Posts 219
Hi PhilLondon
Thanks for that will give it a go.
Sorry for ever doubting you......................................................................
Page 1 of 1 (20 items)
