Latest post 05-14-2009 4:53 PM by Toralfsen. 1 replies.
Page 1 of 1 (2 items)
  • 05-14-2009 4:06 PM
    Sound settings on Beocenter 2
    Hi, I am not able to control the sound settings on my Beocenter 2. When I go into the settings, it says "to adjust sound use television". But I have no television connected to the unit. By the way I'm not able to use the Beo4 either. Was earlyer, but did something in the optionsmenu on Beo4, and now it doesn't work.
  • 05-14-2009 4:53 PM In reply to
    Re: Sound settings on Beocenter 2
    OK, so the unit needs to be turned off when I use the options command on the Beo4...figured it out.
