Latest post 05-14-2009 6:28 AM by djram. 2 replies.
Page 1 of 1 (3 items)
  • 05-14-2009 5:22 AM
    • djram
    • Not Ranked
    • Joined on 08-26-2007
    • Posts 78
    • Gold Member
    mcl2av stand alone capability?
    Is it possible to use a mcl2av to drive a pair of beolabs without being connected to a main system via mcl. I figured i might maybe work if you supplied the mcl2av with sufficient power through the mcl connection, to cheat the unit that it is connected to a main system. I could of course try this myself but the only beolabs i have are beolab 2000 and they do not come in handy here.
    Regards
    Hans
  • 05-14-2009 6:11 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: mcl2av stand alone capability?
    Yes, will work. If you have the IR transceiver connected, you can control the devices connected to the input sockets.
    Will also work with passive speakers and an MCL2P.
    Stefan
  • 05-14-2009 6:28 AM In reply to
    • djram
    • Not Ranked
    • Posts 78
    • Gold Member
    Thanks Stefan
    That makes the mcl2av a very versatile unit and useful unit.
