The Beo 4 itself uses a IR frequency that the ATV doe snot support.
2 options should:
- There is a STB controller available that simulates the Apple Remote. You would need to connect an IR Blaster cable from the TV to the ATV. This is how that is running with my BV832 US version that I have for a year or so.
- The other option that I suspect works as was stated above should work too as the IR Blaster supports a frequency that the ATV supports. Again you need to connect an IR Blaster Cable from the TV to the ATV.
The TV should have had one included.
Personally even though I have option 1 running I will try the 2nd at some point as some things will not work with the B&O ATV implementation. I.e. holding the "Go" key down.
Cheers
JK
