Latest post 05-17-2009 8:40 AM by Medogsfat. 3 replies.
Page 1 of 1 (4 items)
  • 05-13-2009 2:24 AM
    How do I connect CD7000 to Beocenter 7007
    Need some help here!
    Just got hold a mint condition Beogram CD7000 and want to connect it to my Beocenter 7007. CD player only has  male 7pin din output plug.
    I tried this in the rear din socket on the 7007 and it worked fine for listening to CD's ( in fact the sound was really excellent)
    The problem is that when this set up is used all the other sound inputs ( deck / tuner/tape) are cut out.  I can press the input buttons but the CD
    sound remains the only live audio.
    Is there a solution to this?? any advice would be much appreciated
    thanks all
    Justin
  • 05-15-2009 2:15 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: How do I connect CD7000 to Beocenter 7007
    Justin,
              did you connect the CD7000 to the input which has a white plastic plug in it? If so you need to replace this and connect the CD to the tape 2 input instead.
    Chris.
  • 05-16-2009 11:15 PM In reply to
    Thanks for the reply Chris .
    Thats exactly what I did !! Have searched the forum and found the solution re: TP2/ RCA inputs and adapting the 7 pin CD lead to 5 pin and
    connecting via a female din to male RCA lead. It all seemed  so simple when I found that din socket!!
    thanks again
    Justin
  • 05-17-2009 8:40 AM In reply to
    • Medogsfat
    • Posts 4,045
    Hi Justin,
                 there are 2 pins on the 7 pin plug which carry the datalink signal to the CD7000 which simply unscrew which enables you to use a 5 pin DIN to phono/RCA converter (I forgot that the tape 2 input on the 7007 was phono/RCAEmbarrassed). Don't lose these pins though as they are near impossible to find - I would tape them to the cable to ensure you know where they are.
    Get a 5 pin DIN female to 4 X RCA to ensure that you will have the correct wiring (this will be fully wired) - a bit of trial and error will be needed to get the corrct 2 phono outputs.
    The socket you plugged the CD7000 into is for connecting an equaliser and this plug must be replaced or you won't get sound on any function.
    Chris.
