Dear Michael Kevin
Thanks that is exactly what I am looking for
Regarding compatibility
I thought I would stick with Panasonic as from what I have read in the forums that anything from Panasonic is likely to be still compatible with the Beosystem 1
Is that correct ?
I am now looking to buy a DVD player also maybe a Blue Ray player also I need a new Flat Screen
Any recommendations that you know are good and also will be compatible with the Beosystem 1
Regarding DVD player although I live in Taiwan I travel to the USA every couple of months so no problem for me to pick up a USA version only thing is it must be Multiregional as my disks are from all regions.
Blue Ray is again the same as above
Regarding the screen I don’t see United Airlines been too excited about me trying to haul a Flat Screen around the world so I will need to pick that up in Taiwan but again any model recommendation would be much appreciated
As I mention I want to try and make what I buy compatible with Beosystem 1
Thanks for all your help so far
Best Regards
Barry
