Latest post 05-10-2009 12:54 PM by nbohemen. 3 replies.
Page 1 of 1 (4 items)
  • 05-10-2009 8:15 AM
    DC cable to connect MCL 2 AV to MCL2 P
    Does anybody know exactly what kind of DC cable has to be used to connect a MCL2 AV to an MCL2 P?
    I don't have that cable, so I'd like to get one somewhere.
  • 05-10-2009 8:24 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: DC cable to connect MCL 2 AV to MCL2 P
    Hi Nico, from what I remeber it is a double ended cable with pretty standard connections. Do you have something like Malins in you part of the world? If so I would just buy two of the connections and make the cable yourself. There was also a mains transformer available that just plugged into the MCL2 AV.
    CraigSmile
  • 05-10-2009 9:31 AM In reply to
    Hi Nico,
    I've also just purchased an MCL2P and MCL2AV without a cable, so I will be obtaining the plugs to make the cable from my local electronics store later this week.  Would you like me to get some spare plugs and make you a cable as well?
    The plugs are "standard" DC power plugs, but there are MANY "standard" sizes (some of which vary in size by less than 1mm), so I will be taking the MCL2AV into the store to ensure that I get the exact replacements.
    You can contact me via my sponsor link at the foot of this page if you need any assistance.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 05-10-2009 12:54 PM In reply to
    Hi Steve,
    Thanks for the offer, but I think I am first gonna let my electronics store nearby take a look at it. If they fail, I'll contact you.
    Keep me updated!
    Nico
