Latest post 05-09-2009 6:29 PM by Jandyt. 2 replies.
Page 1 of 1 (3 items)
  • 05-09-2009 5:03 PM
    Beogram 3000 connection to a Beomaster 2200
    Hi, I'm trying to connect a Beogram 3000 with 7-pin DIN plug to a Beomaster 2200 with 5-pin DIN phono socket. Since I don't plan to use Beolink I thought it would be OK just to snap off the extra pins in the Beogram plug. If anyone has tried this, your help would be much appreciated?
  • 05-09-2009 5:11 PM In reply to
    Re: Beogram 3000 connection to a Beomaster 2200
    The two pins should be able to be unscrewed. Perfectly reasonable to do this - keep the pins safe somewhere though. They can be reattached if you need to in future. Don't just snap them off though!
  • 05-09-2009 6:29 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    I Selotape the unscrewed pins to the cable. Never lose them that way.
    Poor me, never win owt!
