Latest post 05-31-2007 10:47 PM by David. 3 replies.
Page 1 of 1 (4 items)
  • 05-31-2007 4:37 PM
    • David
    • Top 500 Contributor
    • Joined on 05-05-2007
    • England
    • Posts 128
    Can you use the Beo4 to access Sky info?
    When I'm flicking through the Sky channels with my Beo4 is it possible to access the programe info with the Beo4 instead of using the (i) button on the Sky remote?
    Beolab 8000, Beolab 6000, Beolab 2, LG CX65, Beosystem 3, Beosound 9000, Beolab 3500
    Filed under:
  • 05-31-2007 4:41 PM In reply to
    Re: Can you use the Beo4 to access Sky info?
    GO GO, or Menu 5
  • 05-31-2007 5:10 PM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    GO 5
  • 05-31-2007 10:47 PM In reply to
    • David
    • England
    • Posts 128
    Thanks Guys.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
