Latest post 05-11-2009 8:48 AM by Quim43. 4 replies.
Page 1 of 1 (5 items)
  • 05-08-2009 7:40 AM
    • KibitoCH
    • Top 500 Contributor
    • Joined on 02-19-2009
    • Switzerland
    • Posts 82
    XML Generator broke (Lintronic Softwareupdate)
    Hey Keith
    Lintronic had a Software- Update and is now displaying the Output Box of "High/Low" as follow:
    Pulse, Pause in micro-seconds
    03576 ( 271 ) 01627 ( 123 )  = 5203 ( 394 )
    00531 ( 41 ) 00341 ( 25 )  = 872 ( 66 )
    00532 ( 41 ) 01218 ( 93 )  = 1750 ( 134 )
    00532 ( 41 ) 00344 ( 27 )  = 876 ( 68 )
    00531 ( 41 ) 00342 ( 25 )  = 873 ( 66 )
    00533 ( 41 ) 00342 ( 25 )  = 875 ( 66 )
    00532 ( 41 ) 00341 ( 25 )  = 873 ( 66 )
    00532 ( 41 ) 00342 ( 25 )  = 874 ( 66 )
    00531 ( 41 ) 00343 ( 27 )  = 874 ( 68 )
    00530 ( 41 ) 00341 ( 25 )  = 871 ( 66 )
    00532 ( 41 ) 01220 ( 93 )  = 1752 ( 134 )
    00531 ( 41 ) 01219 ( 93 )  = 1750 ( 134 )
    00532 ( 41 ) 00343 ( 27 )  = 875 ( 68 )
    00530 ( 41 ) 00343 ( 27 )  = 873 ( 68 )
    00530 ( 41 ) 01218 ( 93 )  = 1748 ( 134 )
    00532 ( 41 ) 01219 ( 93 )  = 1751 ( 134 )
    00531 ( 41 ) 00344 ( 27 )  = 875 ( 68 )
    00531 ( 41 ) 01218 ( 93 )  = 1749 ( 134 )
    00530 ( 41 ) 01220 ( 93 )  = 1750 ( 134 )
    00531 ( 41 ) 01220 ( 93 )  = 1751 ( 134 )
    00530 ( 41 ) 08881 ( 675 )  = 9411 ( 716 )
    As you can see, the Format changed totaly. The XML Generator will still create the File, but you wont be able to Serialize it in the Beo5 Tool.
  • 05-08-2009 8:17 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: XML Generator broke (Lintronic Softwareupdate)
    Hi
    Keith said:
    "It should be noted that on 3rd April 2009 Lintronic released a new version of their configurator programme which supplies the timing information output in a different form which is NOT compatible with version 1.1 of the XML Generator.
    Anyone who has installed the new version of the Lintronic Configurator and wishes to make an XML file for their 3rd party product should capture their timings in the normal way and add them to a zip file and upload that zip file HERE and send me a mail. I will produce an XML file from these timings in this new format and e-mail it back to you."
    Regards
    Quim
  • 05-08-2009 12:47 PM In reply to
    • KibitoCH
    • Switzerland
    • Posts 82
    Ok that is very nice, but is there an Update on the way? I do alot of Remotes constantly. And Mailing it also costs time. I mean somehow Keith also has to be able to do it. So there should be a way, i dont think that he is altering all the files by hand Smile.
    I had an earlier Lintronic Software stored on my PC, temporarly i am able to do it. But since they changed the Firmware of the TT455 too, id rather have the latest Software on my PC.
    Regards
  • 05-11-2009 7:32 AM In reply to
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    Hi
    Yes, there is an update on the way, i have sent Keith the new version today, he will then make the new version available.
    The latest version can convert both the old Lintronic and the new Lintronic timings.
    /Weebyx
  • 05-11-2009 8:48 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Weebyx:
    Hi
    /Weebyx
    Thanks, Jacob
    Great job and great news Smile
    Quim
