Latest post 05-08-2009 2:58 AM by elephant. 6 replies.
Page 1 of 1 (7 items)
  • 05-07-2009 10:39 PM
    • omid
    • Not Ranked
    • Joined on 05-08-2009
    • Posts 3
    beosystem 6500 & beo4 & ipod
    Hi All,
    I am very new to this world and would greatly appreciate your help.
    Recently I purchased a beosystem 6500 complete set with record player, tape, cd and amp. It came with a master control remote which is not very convieniant, so i purchased a beo4 remote additionaly.
    The beo4 did not come with a user manual got it from ebay.
    I have connected my ipod to the aux of the beosystem amp.
    The question I have is that there is no Aux button on the beo4 what can I do? is there any way to program the remote?
    Also I do not see a phono button on the beo4 for the record player.
    Any help would be appreciated.
    Omid
  • 05-07-2009 11:03 PM In reply to
    Re: beosystem 6500 & beo4 & ipod
    Hi & congratulations on your pruchases
    To add soft buttons to the Beo4 you need to use this routine:
    1/ press and hold the STANDBY button [●] and then press [LIST] together with the STANDBY, now let go
    2/ "ADD?" will appear in the little display window
    3/ press [GO] to get the soft buttons you can add
    4/ press [LIST] repeatedly to scroll through the list of buttons to add (or use [v] or Cake)
    5/ eventually you will see "A.AUX"
    6/ press [GO] to select "A.AUX"
    7/ "ADDED" will appear in the little display window
    now any time you need the AUX just keep pressing [LIST] until you see "A.AUX" and then press [GO] and you should have your iPod connected and then you can press play on the iPod or whatever :-)
    Good luck !
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 05-07-2009 11:13 PM In reply to
    • omid
    • Not Ranked
    • Posts 3
    Thank you very much for you reply,
    I appologize but I don't understand what you mean is this how you can program the remote? so if I want to swict to Aux, how can i do it?
  • 05-07-2009 11:24 PM In reply to
    sorry I was ediiting the post while you were reading it :-0
  • 05-07-2009 11:41 PM In reply to
    • omid
    • Not Ranked
    • Posts 3
    you are awsome thank you very much it worked!!
    May I ask you another question please, if i purchase a generic docking station for my ipod touch which comes with its' own remote, would it be possible, also to program the beo4 to control the ipod doc functions which it's own remote controls?
  • 05-08-2009 2:23 AM In reply to
    Different infrared frequencies, but you can buy a modded docking station that understands B&O's infrared.
    If your Beo4 doesn't have PHONO, then you can use N.RADIO (added as described above) to initiate record playback. (Hey, I knew I'd get to pass this tip along one more time!)
  • 05-08-2009 2:58 AM In reply to
    omid:
    see this thread ... I am still thinking of bidding for it myself :)
