Latest post 06-06-2009 7:31 PM by ablaumeise. 5 replies.
Page 1 of 1 (6 items)
  • 05-07-2009 4:22 PM
    Anyone out there with a single Beovox S30?
    I know it sounds strange, but: I'm looking for a single BV S30 Type 6301, preferably in rosewood.
    I own four of these, they are used with my BM2000. All except one in mint condition, one pair even had the original price tag on.....and then I managed to drop one of them last week. Was painting the walls and had to remove the S30 from its shelf....and somehow it just happened.
    Luckily it was the one that was already damaged (a small ding on the top), but now the case is totally crushed and the woofer is broken.
    Maybe there is someone out there who had the same problem and who still has a single S30?
    If not, I would also take a single woofer - I can still repair and repaint the case. But then it wouldn't match the other three ones....
  • 05-07-2009 5:41 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Anyone out there with a single Beovox S30?
    I'm sure I can find a woofer but it sounds as if a complete speaker would be best.
    I will look for one.
  • 05-07-2009 6:52 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Got a funny feeling i have a pair you could have...  let me check tomorrow...
    Lee
  • 05-09-2009 7:50 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Good news!  I have a boxed, pristine pair !!
    You can have them, free of charge.  I can't do them any cheaper than that, and that's my final price. Wink
    Lee
    Yes -  thumbs up
  • 05-09-2009 7:27 PM In reply to
    Thanks, that really is a great offer.
    I've sent you a PM. Hopefully shipping isn't that expensive...
  • 06-06-2009 7:31 PM In reply to
    It's been one month now and not even one pair of S30s appeared on eBay. Sadly shipping for Lee's was a bit too expensive in my opinion, so I tried to find a pair on eBay Germany (thats where I got the others more or less for free - bought two complete systems and sold on the other components).
    After all I'm still looking for a new woofer...
    I reworked the casing and painted the two Beovoxs white. Looks even better than before in my opinion. Smile
    So if there is any possibility to get a matching woofer for a reasonable price I would happily take it.
    Or is there some way to repair the original woofer? The magnet became loose - thats all that happened. But I guess just glueing it back on isn't the solution...
