Latest post 08-10-2010 3:38 PM by Keith Saunders. 27 replies.
Page 2 of 2 (28 items) < Previous 1 2
  • 08-07-2010 7:49 AM In reply to
    Re: Beo5 and Philips TV
    Hangglider,
    Your Feller BeamIT remote arrived this morning.
    I did a quick 10 minute review of it and I can see why Lintronic and everyone else has been having problems and also why the B&O supplied XML will never work and I guess it was not tested unless it is intended for a different Feller remote.
    This remote appears to use an "Unmodulated" signal, in other words there is no carrier frequency which is a big problem for most receivers because the normal way of determining the "pulse" size is to count the carrier frequency periods which in this case cannot be done.
    Tomorrow I will do further tests to see if I can come up with a solution to this issue.
    Regards Keith....
  • 08-10-2010 2:54 PM In reply to
    Hi Keiths,
    I feared, that this Feller remote is very speicific. I did another test with a Logitech Remote today. It is the model 895 with IR and RF transmitter. With this model I could setup the Feller and it worked. Maybe this could help you to find a solution.
    Again, thank you very much for your work!
    Hangglider
  • 08-10-2010 3:38 PM In reply to
    I have decoded your BeamIT remote and I can confirm it uses "Pulse Distance Encoding" using 80 micro second pulses with a typical pulse train of 13.5 milli-seconds
    B&O remotes use the same type of encoding method, but the pulses are 270 micro seconds and the overall pulse train is about 140 milli seconds using a totally different protocol.
    I have re-produced your BeamIT binary string on the Beo5 which works, but you will need to test it.
    I will be sending you an XML file for test tomorrow.
    Regards Keith....
