Latest post 07-20-2009 5:14 AM by BeoMatt. 4 replies.
Page 1 of 1 (5 items)
  • 05-07-2009 5:44 AM
    • BeoMatt
    • Not Ranked
    • Joined on 12-13-2007
    • Norwich
    • Posts 51
    Beogram CDX 2 Faulty playback
    Sad Hi everyone, I have allready posted a message here about this http://forum.beoworld.org/forums/t/26136.aspx But I thought if I posted it here it may be better placed. Firstly it was sent by a courier to a colleague very very well packed, he reports on arrival there was no visible damage, but on playing a cd it only managed the first 45 secionds of a track followed by a crackling sound from the speakers. The Beogram CDX 2 worked fine other than the usual lid lifting problem prior to dispatch. Is there any calibration soloutions or maintenance technique anyone could suggest. Matt
  • 05-08-2009 6:02 AM In reply to
    • BeoMatt
    • Not Ranked
    • Norwich
    • Posts 51
    Re: Beogram CDX 2 Faulty playback help me help me please
    Unsure I received the returned Beogram CDX this morning, there is no visible defect anywhere, the cd mechanism floats correctly and the laser moves with no interuption. However the Beogram will only play for about a minute to a minute and a half and then just stop spinning. So it differs slightly from the crackling sound report earlier. I did not experience any crackling just the cd stopping, occasionaly a little spin up and then stop again. Matt
  • 05-09-2009 10:34 AM In reply to
    • BeoMatt
    • Not Ranked
    • Norwich
    • Posts 51
    Big Smile I have been doing my homework like a good little boy and noticed several posts about B&O cd's stopping or shutting down. The common link seems to be the laser needing a clean, I have gentlly brushed over the surface with a cotton bud as suggested and now playback has been extended to 2-3 minutes. hmmmm ?? perhaps it is just a lens clen needed ?? matt
  • 06-02-2009 6:05 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Matt,
    I see that the unit has the CDM2/10 laser-transport.
    I've recently been down the same road with mine!
    You're going to have to disassemble the laser from the circuit board and replace the laser.
    The CDM2 has the best motor ever produced in CD units (a magnetic Hall unit), but one of the least reliable laser units (according to Philips "experts").
    Then Philips released the CDM4 as a replacement, with a cheap DC motor, but a much more reliable laser.
    So, I'm sure that you're already putting 2+2 together, and coming to the conclusion that you're going to keep your CDM2 motor, but substitute in a new (100% compatible) CDM4 laser unit instead.
    Of course, no parts are still available new, but used CDM4 parts are available on ebay.
    Here are a couple of links for used CDM4 units - you want just the laser from them.
    http://cgi.ebay.com/?ViewItem&item=280350711753
    http://cgi.ebay.com/?ViewItem&item=270398644679
    http://cgi.ebay.com/?ViewItem&item=270398646192
    Edit - correction - there IS a source for NEW CDM2=CDM4 laser units here - pricey though!
    http://www.ersatzteil.justone-schnepel.de/html/philips_cdm2_10_cdm-2-10.html
    In the CDM2 service manual, there are caveats for setting up after substituting the "new" CDM4 laser.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 07-20-2009 5:14 AM In reply to
    • BeoMatt
    • Not Ranked
    • Norwich
    • Posts 51
    Thankyou very much for such sound advice, apolagies for the late reply. Matt
