Latest post 06-02-2009 2:51 AM by Dillen. 5 replies.
Page 1 of 1 (6 items)
  • 05-07-2009 3:33 AM
    beomaster 2000 light bulbs
    hey, i just got a beomaster 2000 (2801) with S45 speakers and im in the process of fixing some of the things that are broken. the dial pointer light buld is blown and i cant find any where what the bulb is, can any one tell me what kind of buld it is?
    thanks
  • 05-07-2009 11:14 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: beomaster 2000 light bulbs
    Hi and welcome to Beoworld !  Yes -  thumbs up
    There's a lamp kit available for the Beomaster 2000 (and 4-channel brother 3400)
    containing a complete set of fresh lamps plus a couple of components to take
    care of a few original electronic design flaws.
  • 05-08-2009 1:11 AM In reply to
    cool! so where can i get it?
  • 05-08-2009 2:33 AM In reply to
    • Dillen
    • Posts 5,008
    Here. You have a message in your inbox (top right corner).
  • 06-02-2009 2:16 AM In reply to
    Hi Martin,
    Do you know of a lamp kit for the Beomaster 1900?
  • 06-02-2009 2:51 AM In reply to
    • Dillen
    • Posts 5,008
    Yes, a lamp kit is available (from me) for Beomaster 1900 /1900-2 / 2300 / 2400 and 2400-2.
    Many people seem to think that the panel lights are LED diodes but they are actually filament lamps and the lamps specs are
    critical for correct operation. The kit contains a full set of fresh lamps (plus a spare) and comes with (dis-)assembly instructions/photos.
    The lamps are soldered in so you will need basic soldering skills and electronic tools to replace the lamps.
    There's a good chance that most or all of the old lamps are of the same age and if one lamp burns, others will be marginal.
    Besides, the unavoidable vibrations from servicing and replacing an old lamp will most likely cause the filament in one or more
    of the other old lamps to break, this is very common since the filaments get brittle with time, so I recommend replacing them all
    in one go. This will also give you an equal light output.
    Capacitor kits are also available for most Beomasters, Beocenters etc. (incl. the above mentioned) and highly recommended.
    Send me a message for details. (Click my name "Dillen" to the left and then "start a conversation").
