Latest post 08-08-2009 3:25 PM by Hungedu. 5 replies.
Page 1 of 1 (6 items)
  • 05-06-2009 3:18 AM
    Beovision 4 65' old vesion is that better than samsung LED TV
    hello
    I want to got a Beovision 4 65' with Beosystem 1
    That is not HD tv...
    only 1.049.088 pixels (1366 × 768 × R, G, B)
    How is wealth(worth?)... any comparable one?
    Can you tell me about it...anything...    recently wealth(worth?)
    thanks
  • 05-06-2009 2:11 PM In reply to
    • Michael
    • Top 200 Contributor
    • Joined on 05-23-2007
    • Atlanta, USA
    • Posts 318
    Re: Beovision 4 65' old vesion is that better than samsung LED TV
    Can you rephrase the question?  Are you asking about the image quality?
    -Michael
  • 05-06-2009 4:42 PM In reply to
    Yes,  You are right
    I'm asking about image quality.
    thanks
  • 05-06-2009 4:59 PM In reply to
    • Michael
    • Atlanta, USA
    • Posts 318
    It should be pretty darn good as long as you are viewing from a decent distance (8"+).  I don't know about the LED Samsung but I know that I like the plasma better than LCD.
    I always liked the BS1 but keep in mind that it only has one component input unless you add a Zektor component switch (recommended) which allows for 4 total component sources.  If you need the extra inputs than search the forum for more info on the Zektor.
    Also there is no digital TV tuner so you will have to use an external tuner/cable/satellite feed for any TV viewing once they pull the plug on analog broadcasts this summer.
    -Michael
  • 07-27-2009 3:05 AM In reply to
    Normal 0 false false false MicrosoftInternetExplorer4
    <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} a:link, span.MsoHyperlink {color:blue; text-decoration:underline; text-underline:single;} a:visited, span.MsoHyperlinkFollowed {color:purple; text-decoration:underline; text-underline:single;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} -->
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    LED-backlit LCD TVs do differ from conventional LCD TVs in some important areas:
    1- They can produce a very bright image and deep blacks (doesn't work for Edge-LED
    2- With Edge-LED lighting they can be extremely slim.
    3- They can offer lower power consumption.
    4- They can offer a wider colour gamut, especially when RGB-LED backlighting is used.
    LED TV is a term used by Samsung to describe its line of LCD (liquid crystal display) TVsthat use LED backlighting.
    Filed under: , , ,
  • 08-08-2009 3:25 PM In reply to
    • Hungedu
    • Top 500 Contributor
    • Joined on 08-08-2009
    • Ambergris Caye, Belize
    • Posts 128
    I've seen both in person, and the Samsung LED looks better.
    BeoVision 7-55 3D, BeoSound 9000, BeoSound 8, BeoLab 7-6, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, LC-1, BeoTime (analog clock), Form 1 headphones, Beo 4 remote.
