Latest post 05-05-2009 4:14 PM by Peter. 6 replies.
Page 1 of 1 (7 items)
  • 05-04-2009 12:44 AM
    MMC4 Cartridge and Beogram 8002...
    Greetings to all:  I have a Beomaster 8000 and a Beogram 8002.  I have been using an MMC-4 cartridge.  I have tried  to upgrade with an MMC-2 cartridge.  I have tried two different MMC-2 cartridges at different weight levels.  No luck.  Once, one of them worked, but when I tried to adjust the weight level, I couldn't get the MMC-2 cartridge to work a second time.  I am not sure what the problem is.  Is it possible to use the MMC-2 with the Beogram 8002?  Anyone else have a problem similar to this?  I would be grateful for any information you might have.  Best wishes, Donald
  • 05-04-2009 1:38 AM In reply to
    Re: MMC4 Cartridge and Beogram 8002...
    Hi Donald
    Yes it's possible the 8002 was "born" with the mmc2.If those you tried are used they are not ok.
    regards
    jan
  • 05-04-2009 2:57 AM In reply to
    Agree. The MMC2 is the standard fitting. If the MMC4 works, there is no reason the MMC2 should not - the cartridge body is identical = only the cantilever and diamond differ. You can get the MMC2s repaired - I have just had one of mine done which had a snapped cantilever. Have a look at http://www.schallplattennadeln.de/ - Axel is very friendly and immensely quick.
  • 05-04-2009 6:34 AM In reply to
    Thank you for gettng back to me.  The MMC 2's were purchased from another B&O owner.  The packages were sealed and sold as new.  I am quite discouraged about this and not sure what to do about it.  Donald
  • 05-04-2009 8:20 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Hi Donald.
    It sounds as though the suspension has hardened over time which is quite common even in so called "new old stock" ones. I would send them to Axel and have the suspension renewed (I assume he can do this?) - the cantilever & stylus should be fine if they were sealed items.
    Or you could ask the seller to refund you.
    Chris.
  • 05-05-2009 2:49 AM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    I agree with Chris in sending them in for repairs. Unless you paid a huge amount for them in the first place, in which case I would consider going for a refund.
  • 05-05-2009 4:14 PM In reply to
    I would get a refund - not suitable for use. It is all very well but you probably paid quite a bit and Axel will charge a fair bit to fix them - he has to take them apart.
