Latest post 05-07-2009 5:46 AM by BeoMatt. 11 replies.
Page 1 of 1 (12 items)
  • 05-03-2009 3:14 PM
    • BeoMatt
    • Not Ranked
    • Joined on 12-13-2007
    • Norwich
    • Posts 51
    Help and advice needed for Beogram CDX 2
    Unsure Hi everyone, I have recently sent a Beogram CDX 2 by DHL to a fellow ebay member.
    The CDX arrived but now the player will not play a complete track, it stops working with a cracking noise coming from the speakers at around the one minute mark give or take a few seconds, has anyone come across this fault and have a quick fix soloution, else a full refund and a battle with DHL is on the cards, Matt
    Filed under:
  • 05-03-2009 4:06 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Help and advice needed for Beogram CDX 2
    Check if something is blocking the lasers path. It should be able to move freely through the whole path.
  • 05-03-2009 4:42 PM In reply to
    • BeoMatt
    • Not Ranked
    • Norwich
    • Posts 51
    Thanks Dillen, yes it may have been jolted during transit and become inhibitedBig Smile
  • 05-05-2009 8:39 AM In reply to
    • BeoMatt
    • Not Ranked
    • Norwich
    • Posts 51
    Sad No my colleague has had a look, the mechanism is floating correctly and the laser moves ok he thinks it's electrical?? Has anyone else had similar issues ? Help and advice is always greatly apreciated, Matt
  • 05-05-2009 8:41 AM In reply to
    • BeoMatt
    • Not Ranked
    • Norwich
    • Posts 51
    His report is that it plays a cd for give or take one minute and then a crackling sound comes from the speaker ? Matt
  • 05-05-2009 8:45 AM In reply to
    • Dillen
    • Posts 5,008
    It could be the flex cable running to the swinging laser block. I've seen cases where a couple of the
    leads in the cable broke as if the cable had a hard bend right there.
    Contact was only present with the cable at certain angles.
    Will it play the first minute of any track on a CD or just the first minute of any CD ?
    Was it secured for transport ?
  • 05-05-2009 8:47 AM In reply to
    • Dillen
    • Posts 5,008
    Your tech guy could check the flex cable connector, where the flex cable goes to the board. And its solders.
  • 05-05-2009 8:50 AM In reply to
    • BeoMatt
    • Not Ranked
    • Norwich
    • Posts 51
    Smile Cheers Dillen I shall point him to this forum post and maybe he will join us, Matt
  • 05-05-2009 9:00 AM In reply to
    • BeoMatt
    • Not Ranked
    • Norwich
    • Posts 51
    Embarrassed As for the transit screws/fitting, no, it was missing on the player, so I thought it unwise to interfere with it, oh what a mistake I have made !!
  • 05-05-2009 9:03 AM In reply to
    • BeoMatt
    • Not Ranked
    • Norwich
    • Posts 51
    I did place a small piece of bubblewrap inside to prevent the swing arm from moving though Embarrassed
  • 05-07-2009 5:11 AM In reply to
    • BeoMatt
    • Not Ranked
    • Norwich
    • Posts 51
    Indifferent The Beogram is being returned, so I have listed it on ebay as a spares or repair. even though it does work sort of. I will have a good look at it this weekend and update you, thanks for the advice, Matt
  • 05-07-2009 5:46 AM In reply to
    • BeoMatt
    • Not Ranked
    • Norwich
    • Posts 51
    I have also moved this post to the technical egg head section here http://forum.beoworld.org/forums/p/26212/201851.aspx#201851
    Matt
