Latest post 05-03-2009 5:31 AM by PhilLondon. 2 replies.
Page 1 of 1 (3 items)
  • 05-02-2009 11:55 PM
    • Scud
    • Not Ranked
    • Joined on 11-12-2008
    • Australia
    • Posts 16
    BeoVision 8 Tuner
    Hi there guys;
    how are you?
    I was just looking at buying a BeoVision 8 26" for my bedroom, however i really dont want to buy it if i doesnt come with a High Definition tuner, whilst its been called a HDTV for some reason, im doubting the fact it has a HD tuner. If not, is it available as an inbuilt option or not? And how much would such an option be.
  • 05-03-2009 3:57 AM In reply to
    • Scud
    • Not Ranked
    • Australia
    • Posts 16
    Re: BeoVision 8 Tuner
    Sorry, i'd like to just add/edit that rather then having to have a HD tuner, i will want a digital tuner.
  • 05-03-2009 5:31 AM In reply to
    You are right, You should not buy a tv without a DVB-T tuner, as analog is going to be turned off soon.
    HD however is not necessary on a small screen like a BV8-26
