1st March February 2012
Latest post 09-25-2007 7:27 PM by burantek. 28 replies.
beodim
- Joined on 04-17-2007
- Switzerland
- Posts 130
Peter:Rather depends on the design. I would suggest a repeated pattern of the logo in diagonal rows with maybe just one mention of Beoworld at the bottom left hand side. If there were more in the way of writing, one would feel like an employee and would not wear it. Maybe even just the logo! And it would need to be silk!
I support Peter's suggestion regarding the logo-based pattern and that the word "Beoworld" should be discreet (if at all). And the tie should match the high profile of B&O, i.e. no cheap stuff.
BV7-40, BC6-26, DVD2, BCordV8000, BS4, BS2, BS Ouverture, BC9500, BM8000, BCord9000, BL8000, BL6000, BL2, BL3, BVox4500, BCom6000, Beomedia1, BCom5, Serenata
Daniel
- Svinarp, Sweden
- Posts 1,284
How about a Beo4 in a string? Handy!
Daniel
- Svinarp, Sweden
- Posts 1,284
I wasn´t thinking of an image!
Stars
- Joined on 04-24-2007
- London
- Posts 1,483
As already mentioned, I would buy one if made from silk with a smart and modern design. If you do go ahead with the idea look at ties by KENZO for some inspiration and research. Keep us posted Dad, and a few images would be great if possible.
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Heyup Dad! So that lad of yours has even dragged you into his ventures has he - is there no rest for you? To answer your question - yes I'd buy one. Chris.
Peter
- Joined on 02-12-2007
- Posts 9,572
I imagined something like this.
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Like the design Peter, I would buy one too. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Kevin
- Joined on 02-15-2007
- Moderator
- Posts 1,256
I like it too. Would have to be silk. Slightly smaller logo though and definately no text. What about a small gold f and doing a limited founder version?
Peter
- Posts 9,572
Bit like this? I would do the logos smaller but they go all smudgy if I do that!
Kevin
- Moderator
- Posts 1,256
That's the sort of thing maybe put the f slightly into the logo where there is a space bottom right with the bottom of the f sticking down a bit? If that makes sense. Kevin
