Latest post 05-01-2009 3:41 PM by gk31ax. 8 replies.
Page 1 of 1 (9 items)
  • 04-30-2009 3:15 PM
    Bedroom setup advice needed.
    Was looking at one of the used b&o sites, the beocenter av5 and the 28inch avant both seem to fit the space.
    Has anyone heard the sound from them? which one sounds nicer?
  • 04-30-2009 5:15 PM In reply to
    Re: Bedroom setup advice needed.
    They are both excellent - the AV5 does have a rear facing sub woofer though. The AV5 is a bit odd though - no video source ! And 4:3 aspect. I would get the Avant unless the AV5 is cheap!
    Good question that, I would think the avant.  I think they are like a set of lab4000's
  • 04-30-2009 6:43 PM In reply to
    Go for the Avant, unless you need the sound sources of the AV5
  • 04-30-2009 9:57 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    I had the same thoughts, and decided to get a Beocenter 1, same price, video source, everything built in, powerful sound, a good compromise between the two (avant and AV5)
    If i could go back and choose, i would have found an AVANT 28 , because i know am masterlinked, and the AVANT could access all those sources, with a bigger better picture.
  • 05-01-2009 12:31 AM In reply to
    • saf
    • Top 150 Contributor
    • Posts 458
    I’ve had an Avant 28’ for years in our bedroom and was/am quite happy with it – it’s, of course, (quint)essential to have your bedroom linked … J
    However, at the moment I’m considering another solution: Beoport (video enabled), large LCD screen, wireless keyboard and mouse plus a pair of speakers.
    Now, beside the LCD screen, I already have everything needed even a spare BL2, but why not second hand BL4000, or other speakers, in your case. They will not date as fast as an an Avant!
    -          The Beoport (and the computer) are hidden , so what you see is the speakers and the screen – and the IR eye. Arguably less bulky than Avant, and much better sound.
    -          It gives you (subjectively) more flexibility, in that you on the same screen can go through you music library and make your playlists while surfing on the internet – or work  – from your bed. Plus all other benefits of a link room …
    -          The video quality (on a full screen) is not that impressive in the case of Beoport, but neither is the picture on a linked TV set.
    Every setup has it’s pros and cons, it’s fortunate that with B&O there are usually several options available …
    All the best finding the right solution!
    (Anyone has the setup as outlined? Your experience would be interesting!)
  • 05-01-2009 9:15 AM In reply to
    I had an mx3500 but changed to an Avant 28" - excellent sound and picture, links in properly and by the time you've put the MX on top of something takes about the same amount of space.
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 05-01-2009 9:42 AM In reply to
    I used to have a white MX5500 in the bedroom - lovely tv well suited to a bedroom role IMHO.
    But too heavy to take to Moscow, so I'm instead wallmounting a 24" imac, which gives TV, other media/music, DVD, internet, and will be connected up to some nice B&O speakers  (when we decide on which.... Unsure]
    Add in a wireless keyboard and control via my iphone and Natalia's ipod touch, it is a setup that will compliment the rest of the B&O without being too compromised.
    Ray
    Я люблю Банг и Oлуфсен
  • 05-01-2009 3:41 PM In reply to
    Go for the Avant.....
    My son has a BC1 in his bedroom and we have a 14" Sony CRT built into the wall... guess who's happier!!!!
    I'm actually very pleased with the BC1, sound is very good and I personally don't mind 4:3 and it will hopefully last him at least another 10 years!
