Latest post 04-30-2009 8:31 PM by auric. 10 replies.
Page 1 of 1 (11 items)
  • 04-29-2009 7:42 AM
    • Andy
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Melton Mowbray
    • Posts 128
    Beomaster 8000
    During moving this great Beomaster the glass panel has cracked. It is a friend of mine and who would like to know if you can get replacements??
    Any advice /help would be much appreciated
    Andy
  • 04-29-2009 10:17 AM In reply to
    Re: Beomaster 8000
    You won't get a new one - a scrap 8000 is your best hope though these are few and far between.
  • 04-29-2009 2:55 PM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Re: Beomaster 8000
    I thought that might be the case. What about a good glazier cutting a new one?? Is it red glass or plain with a film?
    Andy
  • 04-29-2009 5:15 PM In reply to
    Re: Beomaster 8000
    Andy:
    It's a smoked or tinted glass that is tempered.
    The problem is getting it cut and the edges precision ground off.
    Most glass cutters I know use a diamond tip cutter and then grind of the edges. This is great for glass tables and shelves but doesn't quite fit the bill for B&O.
    If you can find someone to cut the glass properly then it is not hard make a replacement.
    Mask off the areas where the digits go. The lettering can be made by using a laser printer on film (Black background with white font; the lettering will come out transparent).
    Cut the film and glue it on the glass at the appropriate location. Then spray the entire back of the glass with black paint.
    Finally glue the panel to the metal bracket.
    The only thing that prevents this from being perfect is getting the nice edge on the glass.
    If you can figure out/find someone who can do this we've got near perfect replacment panels!
    Derek
  • 04-29-2009 5:41 PM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Re: Beomaster 8000
    Hi
    thank you. Im a bit confused about the lettering? It looks to me like one pane of glass that goes over the LEDS of volume program etc. Is it just normal clear tempered glass that is sprayed on one side?? Sorry if im complicating it.
    Thanks again
  • 04-29-2009 6:28 PM In reply to
    Re: Beomaster 8000
    Andy :
    Hi
    Thanks again
    Hi there.
    Yes, just ordinary tempered glass, with all the text & colour on the inside. Do please let us know how you get on.
    Ray
    Я люблю Банг и Oлуфсен
  • 04-30-2009 4:18 AM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Re: Beomaster 8000
    still a bit confused by the "text lettering" There does not appear to be any on the glass it is on the beomaster itself?? So im presuming just a colour paint needs applying?
    Andy
  • 04-30-2009 5:15 AM In reply to
    Re: Beomaster 8000
    Andy :
    Andy
    Hi Andy.
    Yes, we're misleading you by inadvertently talking about other B&O stuff that does have text on the underside of the glass.  At least your broken glass is one of the easier ones Smile
    Ray
  • 04-30-2009 7:09 AM In reply to
    • Andy
    • Melton Mowbray
    • Posts 128
    Re: Beomaster 8000
    Thanks yes I think the beocord 8000 and 8004 have text on them.
    Weve found a glass cutter who with confidence believes he can match the glass??? So what should be sprayed onto the under surface??
    Regards
    Andy
  • 04-30-2009 8:56 AM In reply to
    Re: Beomaster 8000
    I've never done more than repair scratches, for which I used a small brush and a tin of Humbrol Black enamel model paint Smile
    This worked very well, and was invisible when the panel was mounted back on the machine in question.
    I'm sure someone else here will have done a full panel, and can better advise you.
    Good luck!
    Ray
  • 04-30-2009 8:31 PM In reply to
    Re: Beomaster 8000
    Andy:
    There is lettering on the underside of the glass. Hold the panel up to the light and you will see.
    After masking off the appropriate area and adhering the lettering to the underside spray the glass with a matte black spray paint. I'd use the high temperature kind used for appliances (ie stoves and furnaces) as they are more durable.
    Derek
