Hi all,
Does anyone know if my AV9000 (SW 1.2) will be able to use one of my HDR1's?
They aren't together at the moment so I can't just plug it in to check!
Cheers
GUY
Train Hard - Run Fast - Hit to Kill!!!
Possibly if used instead of the VCR. I think if you try to use both, you will hit problems.
