        1st March February 2012
	    Latest post 05-11-2009 6:24 AM by  TWG. 19 replies.
								        04-27-2009 10:06 PM
									        Razlaw
								                - Joined on 04-24-2007
								                - Illinois
								                - Posts 1,770
										    Should I switch from PC to Apple?
										    Our system consists of three rooms connected by Masterlink. Room 1 has a BV7 MKIII, Beosound 3000, speakers and Apple TV. Room 2 has speakers with a B and O eye/puc mounted on the wall and an Avant that is not connected to the Masterlink System. Room 3 has a PC with Beolab 4000s and and Beoport. We also have an iTouch that we use to control both iTunes on the PC as well as the Apple TV. Is there any functionality we would gain by replacing the PC with a Mac, probably a Mini?  The PC works fine but since receiving the iTouch as a gift from my wife and purchasing the Apple TV and seeing how well Apple works, I am looking for an excuse to buy a Mac.
Also, we have a Beosound 1 in our bedroom and an unused set of Beolab 4000s. Ca I use Airport Express to connect the sytem to these and if so would it be easier with a Mac than with the current PC?
Thanks!
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
									        PhilLondon
								                - Joined on 04-16-2007
								                - London
								                - Posts 2,545
										    Re: Should I switch from PC to Apple?
										    Airport Express would work the same way on a mac and on a PC. So you'll have to find anothr excuse ;-)
But do you really need an excuse?
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    No, you are correct, I do not really need an excuse. I did think of another question. I am using Beoport and Masterlink to distribute N.Music/iTunes through the various rooms. This works but in order to use iTunes I must press N. Music then Stop on the Beo 4 and then can use the iTouch to control the iTunes.
If I switched to a Mac, am I correct I would still use the Beoport box but would need to download and install the program from Ostrund?
Also, with that program and Beoport would I still need to start N.Music and Stop it or would pressing N. Music take me directly to iTunes without activating Beoplayer?
Thanks!
									        kallasr
								                - Joined on 04-19-2007
								                - Willich, NRW, Germany
								                - Posts 1,077
										    N.Music will take you right there! I am using a Mac Mini with Beoport (BS 3000 as audio master).
Best regards
Ralf
									    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
									        kallasr
								                - Posts 1,077
										    For sure you need to set the programs to start at start-up.
Ralf
									        elephant
								                - Melbourne, Australia
								                - Posts 2,215
										    Sounds like you have a great set-up so I would encourage you to take the step.
I recently bought a Macbook - the first Apple "pc" in our house, and I have been experimenting on the best ways to connect and use it.
In my wintel pc days I started using Beoplayer, then bought a Beoport, and then switched to mainly using iTunes (the old Beoworld contained tales of some of those adventures) - I liked iTunes because I could create cover art for CDs for my wife's car and also because it inetgrated with Last.FM (see my signature block) something I could never get BeoPort/Player to do.
I am using the BM-link software with the BeoPort and either a Beo4 or an Apple Remote.
With both I can use Front Row (but I have not got the Beo4 to fast scroll) -- but I have found my collection is too big for ease of use with Front Row's interface (or my metadata (iTunes tags) is too mixed up).  However Front Row's cover art is nice to have going in the background when we have visitors.
As an aside I have been trialing TuneUp to see if that will improve the metadata including all my blank cover art.
I find the Beo4 manipulation of iTunes difficult and for this reason I would favour a Macmini with a wireless mouse and keyboard over an Apple TV - again this difficulty may be how my collection is (dis)organised but I did find ticking OFF the "group albums by artist" to be useful.
While my explorations are not complete these are some early findings:
1/ I suspect I will not get an AppleTV because I do value integration with Last.FM
2/ I do MISS the B&O announcer's voice in the link rooms - she disappears when using BM-link and Apple
3/ As others have stated elsewhere you also loose the ability to receive ML transmissions i.e. the BM-link software is one-way
If the Beosound 1 has an AUX.IN then you should be able to make use of an Airport Express - but I suspect it will make no difference if the iTunes source is on Apple or on a wintel.
Not sure about the Beolab 4000s - for them I suspect the B&O Wireless approach may be the best/safest approach; but I did find a very interesting article under Forums » BeoWorld around the world! » BeoWorld Skandinavien » which I could not translate at http://forum.beoworld.org/forums/p/311/14424.aspx#14424 Itunes -> Airport Express -> Beolab 4000
It seems to be about how to wise 4000s to iTunes via Airport Express ...... just what you wanted :-)
									    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
									        elephant
								                - Posts 2,215
										    Subsequently to the first post I found instructions in the Scandinavien thread on how to do the translation so here are those two posts almost perfectly translated
I am a high school who spent a significant portion of savings in the following set-up:
 MacBook with iTunes to wirelessly send
music to Airport Express Station, which sends the music through the
mini-jack-RCA cable for my two Beolab 4000 that hangs on the wall.
Thus, my wireless music system complete and sole control is required is on the computer. I myself think it is quite excellent.
 However, there is a problem ..!
Højtalerene is extremely sensitive to the signal and I therefore have to screw down the equalizer in iTunes. That in itself is not a source of
major irritation, but: The sensitivity of højtalerene do that from time
to time (45min - 1.5 hour intervals), switch on and off quickly.
 I know this only happens if indgangsignaleret is weak and very briefly.
 My question is: How can this problem be solved? I have considered whether it is possible to buy a mini-jack-resistance,
which would dampen the signal without compromising the sound.
   In advance, thanks.
 /Thomas
Hello Thomas
 Jeg havde det samme problem.
I had the same problem.
Det blev løst ved at få lavet et adapter kabel hos min B&O forhandler.
It was solved by getting into an adapter cable from my B & O dealer.
Det ser sådan ud.
It looks like this.
Efter
dette kabel blev tilsluttet blev volumen nem at styre. Hvis ikke BeoLab
4000 modtager et lydsignal i et stykke tid går de i standby, det kan
der kun laves om på, ved at få justeret eller fjernet det relæ som
findes i højttalerne.
After the cable was connected to the
volume easy to manage. Unless BeoLab 4000 receives an audio signal in a
while go in standby, it can only be turned on by getting adjusted or
removed the relay which is in the speakers.
Good luck !
									        Razlaw
								                - Illinois
								                - Posts 1,770
										      elephant:
Could you elaborate on this? I do not understand. What functionality would I lose?  Thanks!
									        PhilLondon
								                - London
								                - Posts 2,545
										      Razlaw:
Yes, the software controls iTunes on you mac, so you will not have to press stop, you can control iTunes from your Beo4 (like you could control Beoport on a PC). But you can also control it with the iPod.
BMLink can sometime "lock" your ML network and nothing works on the whole ML until you turn the Beolink PC2 thing off and on again. This happen sometimes when you plug/unplug the USB socket.
A good point is that the song title info that is send over ML to your Hifi is more complete than Beoport.
									        elephant
								                - Posts 2,215
										      Razlaw:
  elephant:
To be absolutely sure I performed a test and will "draw" the basic set-up:
BeoLab 3s === BeoPort === MasterLink === BeoSound 4
The BeoPort connects to either a Compaq latptop (windows) or Apple Macbook by the USB and minijack connections.
With the Windows BeoPlayer/BeoPort software you can add from the MasterLink sources that exist OUTSIDE of the PC. For this I just added A.MEM (the SD card in the BS4), Radio (BS4) and CD (BS4) to the existing Net.Radio, Net.Music, Photo, PC CD and PC sources. (8 appears to be the limit)
So with Windows BeoPlayer/BeoPort software I can with the mouse or with the Beo4 select CD and play my BS4's CD through the BeoLabs (or the BS4's Radio or its SD Card).  If I press PC CD then of course I play the CD in the DVD drive of the laptop.
If however I swap out the Compag and put in the Apple then I no longer have any BeoPlayer/BeoPort software, all I have is the BM-Link that connects iTunes to the B&O World (plus other Mac applications that emit sounds).
Note there is no real user interface anymore - nothing like the BeoPlayer - all you get is the configuration utility described on http://www.odlund.se/bmlink/documentation/pages/software.html
The interface that BM-Link provides for control of speakers (on/off, mute, and volume) is shown in the screen capture below.
Because there is no BeoPlayer/BeoPort software on the Apple I do not get the lady announcing "Connecting" in my link rooms.
Nor do I get access to the audio coming from my BeoSound 4 audio master: no CD, no Radio, no SD Card ... unless I remove the BeoLab 3s from the BeoPort and attach them to an Active box or to a B&O Wireless box.
									        elephant
								                - Posts 2,215
										    Having posted the above message, I then connected my Apple to double check.
And yes you can not "received" audio master signals via the BeoPort+Apple ...
... except ... (drum roll please) ...
... by fortuitous accident I triggered a B&O Wireless IR-eye with my signals, and suddenly the BeoPort's BeoLabs were playing music from the BeoSound audio master
To make this work, on the Beo4 I press N.Music which activates Itunes and the BeoPort and the BeoLabs - I then press STOP on the Beo4 which halts iTunes playing but leaves the BeoLabs active and I then press CD or Radio or A.MEM and I can access the BeoSound 4's sources
A bit of a kludge, and I now have a set-up that looks like this:
BeoLab 3s ==v
Apple === BeoPort ==||
                                    ||=  Master Link === BeoSound 4
         B&O Wireless ==||
So in explaining the issue I have found a workaround (at the cost of a B&O Wireless)
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    Thanks!   Now I understand.
									        TWG
								                - Joined on 04-17-2007
								                - Germany
								                - Posts 950
										    The answer to the original question is YES!
  I switched to the Mac before 2-3 years and my experience so far:
  You do the things you want with your computer and you don't spend all the time with configurating, error messages etc.
  It simply works. It is so simple sometimes that you wouldn't even think of.
  As all actual Macs can run Windows, too there's no excuse, there's only the question: When do you buy it?
  The Operating System of the Macs is realy great to use. Connecting to a wireless network? Don't bother with WPA, WEP etc. Just switch on Airport (that's how Apple calls Wireless Lan), search for the network or enter the name of the network, enter the password and you're done.
  And you got hundreds of "Widgets" - little helpers for your Desktop that you activate with a hit of one button etc. You want to calculate currencies, you need to track a parcel, you're searching for a telephone number, you want to see how much your kids are phoning through your home telephone pbx? There's a widget for nearly everything :-)
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    Your comment that it simply works is why I am thinking of switching. Since acquiring an iTouch and Apple TV I have been amazed that they simply work, easy to configure and they do not lock up or freeze. I do wish however that I could keep the Beoplayer on the main pc. When using that computer I do enjoy the Beoplayer interface/controls.
									        TWG
								                - Germany
								                - Posts 950
										      Razlaw:
 This is no problem, too, as you have 2 options:
 1.) You can use Apples Bootcamp (comes with OS X 10.5 Leopard = every actual Mac) which allows you to install Windows XP on your Mac and choose which OS you can boot. So you can use the Beoplayer on Windows in a nice looking package ;-)
  More information here: http://www.apple.com/macosx/features/bootcamp.html
  2.)  You can use software like "Parallels" that runs Windows XP on a virtual machine inside Mac OS X. In this case you can use Mac OS X AND Windows applications at the same time!
  More information here: http://www.parallels.com/
									        raphdjp
								                - Joined on 04-28-2008
								                - Bordeaux / France
								                - Posts 40
										      TWG:You can use software like "Parallels" that runs Windows XP on a virtual machine inside Mac OS X. In this case you can use Mac OS X AND Windows applications at the same time!
You can also use virtual box. Instead of Parrallels desktops and Fusion from WMWare,  it's a free virtualisation solution from SUN and IBM and it work very well (i use it to configure my LinTronic box)
									    Beosound 9000 & Beolab 8000 & Beogram 4000
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    Thanks!  Another question.....all that we use our desktop for is searching the web, basic word processing, organizing and printing photos and of course, music. Is the entry level Mac Mini sufficient for this or would an upgrade be reccomended?
Thanks!
									        raphdjp
								                - Bordeaux / France
								                - Posts 40
										    The entry level mac mini (or imac or macbook) is largely sufficient for this purpose, in fact the only drawback with all the entry level line is for gaming. The next OS (10.6 or "snow leopard" ) due this summer promises to improve speed for
all the existant and futur mac with "grand central" (better use of multicore processor) and OpenCL (use of the GPU power for all application).
									        Razlaw
								                - Illinois
								                - Posts 1,770
        Page 1 of 1 (20 items)
