Latest post 04-27-2009 11:08 AM by RUDYV. 2 replies.
Page 1 of 1 (3 items)
  • 04-26-2009 4:30 PM
    • RUDYV
    • Not Ranked
    • Joined on 07-31-2008
    • Belgium
    • Posts 52
    • Gold Member
    Master 39 K
    Today I have acquired a Master 39 K.
    After a first check, it looks as if only the dial lamp is missing .
    The dial lamp has been replaced by a Philips deluxe 60W bulb.
    So now I am trying to find a dial lamp which is suitable for this set.
    I am aware that it is almost impossible to find a NOS beolit 39/40 dial lamp.
    Are there any alternitives, maybe a replacement lamp from another brand ?
    All suggestions are welcome.
  • 04-27-2009 7:56 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Master 39 K
    Nice set !
    The dial lamp is mentioned in the service manuals as type "Master 39K".
    Lamps for the Master Deluxe 39K is mentioned as "Master Deluxe 39K".
    They are very similar but, I believe, different - or they would probably bear the same markings.
    The service manuals will provide more info - I will give it some more time tonight.
    While restoring a Beolit 39 recently, I located a new "Master Deluxe 39K" lamp but it didn't
    fit in the Beolit which uses a third type - which wouldn't fit in your set either.
    Differencies in the valve heater chain(s) are the main reason for this, a dial lamp is not just a dial lamp.
    I ended up building a homemade solution, consisting of three resistors to dissipate heat and drop voltage
    and 2x 110V halogen bulbs. Maybe you saw the thread here at Beoworld already.
  • 04-27-2009 11:08 AM In reply to
    • RUDYV
    • Not Ranked
    • Belgium
    • Posts 52
    • Gold Member
    Re: Master 39 K
    Martin, thank you very much for the fast reply.
    Yes, indeed, I saw the thread about the restoring of the beolit 39.
    Very interesting !!!
