FYI
TELEVISION BeoVision 8 - 40
DESIGNER David Lewis
CABINET FINISH Black soft touch/silver
REMOTE CONTROL Beo4 (not included)
POWER CONSUMPTION Typical: 160 W / 1 W
CONTRAST SCREEN No
HD READY Yes
PICTURE AND TELETEXT Yes
TELETEXT Level 1 1/2, 2000 pages Teletext and Picture, 9 memory pages, WSS
SCREEN TYPE 40" 16:9 TFT LCD with glare surface and low reflection coating, display colours 1.08 billion
REFRESH RATE 100/120 Hz
RESOLUTION 1920 x 1080 (Full HD)
VIDEO INPUT FORMATS View PDF
BRIGTHNESS typical 500 cd/m2
CONTRAST RATIO typical 3000:1 RESPONSE TIME typical 6 msec.
VIEWING ANGLE typical +/-89 degrees both vertical and horizontal
OPERATING CONDITIONS 10 - 40 degrees centigrade
TV SYSTEM According to type and setup: B/G/L/L'/I/D/K PAL, SECAM, NTSC on AV. T
UNING 99 programmes, auto tune, programme move and automatic naming
STEREO SYSTEM A2 + Nicam
DIGITAL TV SYSTEM DVB-T/C DVB HD
SUPPORT OF ACTIVE AERIAL (DVB-T) Yes
SUPPORT OF MHEG (UK) Yes
NUMBER OF COMMON INTERFACE AND SMART CARD SLOTS 1 SmartCard slot, 1 PCMCIA
TUNER FREQUENCY RANGE AND BANDWIDTH 110 MHz to 862 MHz (Band 3, 4, 5) IF Bandwidth 6,7 & 8 MHz selectable
HD AND/OR SD DECODING 480i, 576i, 576p, 720p, 1080i
DECODER VIDEO, AUDIO Video: Mpeg2 (MP@ML, MP@HL), H264 (Mpeg4) Audio: Mpeg1, Mpeg2, AAC, AAC+ and AC3 decoding and downmix
SURROUND SOUND SYSTEMS Dolby Digital 5.1, DTS 5.1, DTS Digital Surround | Neo:6, Pro-Logic II,
PLAY TIMERS No MENU LANGUAGES English, Danish, Dutch, Spanish, Italian, German, French, Swedish
LOUDSPEAKERS: EFFECTIVE FREQUENCY RANGE 85 – 20,000 Hz
CABINET PRINCIPLE/VOLUME Closed box/Bass reflex 5 litres
WOOFER / TWEETER Woofer 100 mm, Midrange 50 mm full range type, Tweeter loudspeaker driver 19 mm dome type
BASS EQUALISER Adaptive Bass Linearization (ABL)
AERIAL INPUTS TV: 75 ohms aerial female
DVB-T/C: 75 ohms aerial female
IR CONTROL OUTPUTS (PUC) 4 x Mini jack (PUC1-4)
AV CONNECTORS AV1 21-pin Scart socket 1-way AVL data, CVBS in/out, Audio in/out, RGB, Pin 8 sense. Main usage is: DVD, Decoder, STB and Recorder. AV2 21-pin Scart socket + 3 x phono (Y-Pb-Pr) 1-way AVL data, CVBS in/out, Auto Y/C detect, Y-Pb-Pr, Audio in/out, RGB, Pin 8 sense. Main usage is: High quality video signals (Y/C or Y-Pb-Pr) from STB or DVD Recorder. AV3 15 pin D-Sub (VGA) + 3 x phono (CVBS in and Audio L/R in) This is an input only connection. Main usage is BeoMedia/PC connection either using the CVBS or VGA, but it ca also be used for other input only sources e.g. DVD-player or STB. AV4 (optional System Module) 21-pin Scart socket 2-way AVL data, CVBS in/out, Audio in/out, RGB, Pin 8 sense. Main usage with a B&O DVD/HDR e.g. HDR2
USB 1x USB (for DVB HD software update only)
ETHER NET 1x RJ45 (for DVB HD software update only)
OUTPUT (RECORD OUT) AV1, AV2 and AV4 (CVBS, L/R)
STEREO HEADPHONES 1 x Mini jack BEOLINK Master link, yes if System Module is mounted (optional)
BEOLINK VIDEO DISTRIBUTION 75 ohms IEC-male (Modulator output), yes if System Module is mounted (optional)
LOUDSPEAKER OUTPUTS 5 x PowerLink
DIGITAL AUDIO INPUTS 2 x SPDIF (Coax), 2 x HDMI
PC INPUT VGA/HDMI
