Latest post 04-28-2009 2:38 PM by windmacher. 4 replies.
Page 1 of 1 (5 items)
  • 04-23-2009 7:44 AM
    • HeKoch
    • Not Ranked
    • Joined on 09-29-2008
    • VS-Schwenningen /Germany
    • Posts 46
    endgültige Technische Daten BV8-40
    Für alle,die es interessiert.
    TELEVISION  BeoVision 8 - 40
    DESIGNER David Lewis
    CABINET FINISH Black soft touch/silver
    REMOTE CONTROL Beo4 (not included)
    POWER CONSUMPTION Typical: 160 W / 1 W
    CONTRAST SCREEN No
    HD READY Yes
    PICTURE AND TELETEXT Yes
    TELETEXT Level 1 1/2, 2000 pages Teletext and Picture, 9 memory pages, WSS
    SCREEN TYPE 40" 16:9 TFT LCD with glare surface and low reflection coating, display colours 1.08 billion
    REFRESH RATE 100/120 Hz
    RESOLUTION 1920 x 1080 (Full HD)
    VIDEO INPUT FORMATS View PDF
     BRIGTHNESS typical 500 cd/m2
    CONTRAST RATIO typical 3000:1 RESPONSE TIME typical 6 msec.
    VIEWING ANGLE typical +/-89 degrees both vertical and horizontal
    OPERATING CONDITIONS 10 - 40 degrees centigrade
    TV SYSTEM According to type and setup: B/G/L/L'/I/D/K  PAL, SECAM, NTSC on AV.  T
    UNING 99 programmes, auto tune, programme move and automatic naming
    STEREO SYSTEM A2 + Nicam
    DIGITAL TV SYSTEM DVB-T/C DVB HD
    SUPPORT OF ACTIVE AERIAL (DVB-T) Yes
    SUPPORT OF MHEG (UK) Yes
    NUMBER OF COMMON INTERFACE AND SMART CARD SLOTS 1 SmartCard slot, 1 PCMCIA
    TUNER FREQUENCY RANGE AND BANDWIDTH 110 MHz to 862 MHz (Band 3, 4, 5) IF Bandwidth 6,7 & 8 MHz selectable
    HD AND/OR SD DECODING  480i, 576i, 576p, 720p, 1080i
    DECODER VIDEO, AUDIO Video: Mpeg2 (MP@ML, MP@HL), H264 (Mpeg4)     Audio: Mpeg1, Mpeg2, AAC, AAC+ and AC3 decoding and downmix
    SURROUND SOUND SYSTEMS Dolby Digital 5.1, DTS 5.1, DTS Digital Surround | Neo:6, Pro-Logic II,
    PLAY TIMERS No MENU LANGUAGES English, Danish, Dutch, Spanish, Italian, German, French, Swedish
    LOUDSPEAKERS:   EFFECTIVE FREQUENCY RANGE 85 – 20,000 Hz
    CABINET PRINCIPLE/VOLUME Closed box/Bass reflex 5 litres
    WOOFER / TWEETER Woofer 100 mm, Midrange 50 mm full range type, Tweeter loudspeaker driver 19 mm dome type
    BASS EQUALISER Adaptive Bass Linearization (ABL)
    AERIAL INPUTS TV: 75 ohms aerial female
    DVB-T/C: 75 ohms aerial female
    IR CONTROL OUTPUTS (PUC) 4 x Mini jack (PUC1-4)
    AV CONNECTORS AV1 21-pin Scart socket 1-way AVL data, CVBS in/out, Audio in/out, RGB, Pin 8 sense. Main usage is: DVD, Decoder, STB and Recorder.  AV2 21-pin Scart socket + 3 x phono (Y-Pb-Pr) 1-way AVL data, CVBS in/out, Auto Y/C detect, Y-Pb-Pr, Audio in/out, RGB, Pin 8 sense. Main usage is: High quality video signals (Y/C or Y-Pb-Pr) from STB or DVD Recorder.  AV3 15 pin D-Sub (VGA) + 3 x phono (CVBS in and Audio L/R in) This is an input only connection. Main usage is BeoMedia/PC connection either using the CVBS or VGA, but it ca also be used for other input only sources e.g. DVD-player or STB.  AV4 (optional System Module) 21-pin Scart socket 2-way AVL data, CVBS in/out, Audio in/out, RGB, Pin 8 sense. Main usage with a B&O DVD/HDR e.g. HDR2
    USB  1x USB (for DVB HD software update only)
    ETHER NET  1x RJ45 (for DVB HD software update only)
    OUTPUT (RECORD OUT) AV1, AV2 and AV4 (CVBS, L/R)
    STEREO HEADPHONES 1 x Mini jack BEOLINK Master link, yes if System Module is mounted (optional)
    BEOLINK VIDEO DISTRIBUTION 75 ohms IEC-male (Modulator output), yes if System Module is mounted (optional)
    LOUDSPEAKER OUTPUTS 5 x PowerLink
    DIGITAL AUDIO INPUTS 2 x SPDIF (Coax), 2 x HDMI
    PC INPUT VGA/HDMI
  • 04-23-2009 2:24 PM In reply to
    Re: endgültige Technische Daten BV8-40
    Herzlichen Dank sagt
    TanteInge Big Smile
  • 04-28-2009 3:37 AM In reply to
    vielen Dank,
    hatte schon Sorge, dass von B&O auf den letzten Metern doch noch Anschlüsse/ Module eingespart werden Big Smile. Aber nun sieht es gut aus. Hoffe das Bild ist gut. [:'(]
    Gruß Beroli
  • 04-28-2009 1:39 PM In reply to
    • beo1
    • Not Ranked
    • Joined on 04-18-2007
    • Bochum / NRW
    • Posts 75
    Hallo,
    habe ich das richtig gelesen?
    Der BeoVision 8-40 hat diese Anschlüsse
    an Bord????
    Wer kann das zu 100% bestätigen??
    wenn das so sein sollte, kriegt der 7-40 diese Anschlüsse auch?
    Gruß
    beo1
  • 04-28-2009 2:38 PM In reply to
    Hallo beo1
    Laut Bedienungsanleitug hat er auf jedenfall den USB Port. Der Ethernet ist nicht angegeben (soweit ich das gesehen habe).
    Die Frage ist aber eigentlich; was willst du mit den beiden Anschlüssen machen?  Es steht ja in den Klammern, dass sie nur für Service-Zwecke  nutzbar sind.  Der einzigen Vorteil, den ich darin sehen könnte, ist das Einspielen neuer Softwarestände durch den Kunden und nicht durch den Händler, soweit das überhaupt durch B&O angedacht ist. Wäre natürchlich eine Gute Sache, zumal Loewe oder Metz sowas schon lange ermöglichen.
