Latest post 04-21-2009 4:20 PM by rayfenwick. 8 replies.
Page 1 of 1 (9 items)
  • 04-21-2009 3:03 PM
    • mor
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Cologne
    • Posts 104
    Motorized Stand Question for Beovision MX Series
    Hello Everyone,
    I have a motorized stand under my MX7000. Does anyone know whether it would fit under the last from the series, the MX8000 as well?
    Thanks for any reply!
  • 04-21-2009 3:14 PM In reply to
    Re: Motorized Stand Question for Beovision MX Series
    Physically will fit but the motors are different electrically.
    The 7000 DIN plug has 4 pins and the 8000 DIN plug has 5 pins.
    Regards Graham
  • 04-21-2009 3:24 PM In reply to
    • mor
    • Cologne
    • Posts 104
    Thanks for your quick reply Graham.
    Is there any adapter or would the motorized stand simply be useless for the 8000?
  • 04-21-2009 3:25 PM In reply to
    joeyboygolf:
    Am I right in thinking it should be an easy rewire?
    Ray
    Я люблю Банг и Oлуфсен
  • 04-21-2009 3:47 PM In reply to
    mor:
    It is only the motors that are different, the stand itself is identical.
    Regards Graham
  • 04-21-2009 3:49 PM In reply to
    rayfenwick:
    joeyboygolf:
    The motors are quite different but I can't remember why. It is not a simple re-wire. That has been proposed before and discounted.
    Regards Graham
  • 04-21-2009 3:59 PM In reply to
    • mor
    • Cologne
    • Posts 104
    I live in Cologne, Germany - but we still got a flat in London as well ... but if it's not an easy plug-n-play I probably would not go through the trouble of "upgrading" from the 7000 to the 8000
  • 04-21-2009 4:03 PM In reply to
    mor:
    I have an 8000 type motor which I would willingly swap for a 4 pin type. Is it worth it for you?
    Regards Graham
  • 04-21-2009 4:20 PM In reply to
    There's always a solution Smile
    ...one of the things I LOVE about Beoworld! Yes -  thumbs up
    Ray
