Latest post 05-05-2009 8:57 AM by Emmanuel92. 25 replies.
Page 1 of 2 (26 items) 1 2 Next >
  • 04-21-2009 1:10 PM
    BV7 Sub settings
    We just had the software updated on our BV7. I noticed that in the speaker menu in addition to being able to choose "subwoofer" there are now options for left subwoofer, right subwoofer, front subwoofer and rear subwoofer. I do not recall seeing these options in the old software. Are they new?  Do they have any affect on the performance of the sub? I did not think there was any sort of directional difference in the sub track although physical location of the sub does affect the sound.
    Thanks!
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 04-21-2009 2:14 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: BV7 Sub settings
    Aren't these settings for connecting two BL2s to a BV7-40 MKIII? ie. a BL2 left and BL2 right?
  • 04-22-2009 8:06 AM In reply to
    Anybody have any experience using two subs?  Does setting the BV7 to left right front or rear change the sound that goes to the sub in any manner? I have also noticed that it does allow two different distances to be set for the two subs.
    Thanks!
  • 04-25-2009 8:20 AM In reply to
    Doesn't anybody have any comments or experience with the dual sub settings?
  • 04-25-2009 8:25 AM In reply to
    I really don't have experience in this field, but I have idea maybe to try to daisy chaind them ?
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 04-25-2009 8:45 AM In reply to
    My question is do the settings in the BV7 menu that allow a sub to be specifically assigned a position such as LEFT RIGHT FRONT REAR have any effect on tge sound from the sub? If not, why does the BV7 allow the sub to be assigned a position?
    Thanks!
  • 04-29-2009 8:05 AM In reply to
    Is this a first?  A technical question nobody on the forum can answer? LOL
  • 04-29-2009 9:02 AM In reply to
    Maybe this is related to the speaker distance for each sub. The signal for all the subs is the same, but the time delay is not the same if say for example your Lab 2 #1 is 3m away from the listening position, and your Lab 2 #2 is 4m away.
    What are the menu settings for each sub ?
    Quoi de mieux qu'un BeoLab 2 ? 2 BeoLab 2 !
  • 04-29-2009 9:33 AM In reply to
    I tried two subs on my BS3. But because of the dimensions of the room it didn't impress me. It was over the top!
    If one has a really large room I can imagining one wants a additional sub.
  • 04-29-2009 6:18 PM In reply to
    Emmanuel92:
    The available settings are front,   left,     rear,     and right.
  • 04-29-2009 6:20 PM In reply to
    Carolpa:
    When you tried the two subs did you have them assigned as to their location, i.e. front or rear, left or right or just as two subs with no identification of the position.
  • 04-30-2009 2:56 AM In reply to
    Razlaw:
    Emmanuel92:
    OK. Curious... There is always only 2 PowerLinks outputs for subwoofers, but the software asks for the position of 4 subs ?
    Could you precise how is the menu ? (or have you a picture ?)
    SUBWOOFER ON/OFF
    RIGHT SUBWOOFER ON/OFF
    LEFT SUBWOOFER ON/OFF
    FRONT SUBWOOFER ON/OFF
    REAR SUBWOOFER ON/OFF
  • 04-30-2009 3:06 AM In reply to
    Carolpa:
    Two or more subs do not only give more power (not needed !): sound distribution is more even/coherent. I tested it intensively at my home. The result is definitely much better than only one sub. However my room has modest size: 4m large * 5.5m long.
    I tested with 3 Lab 2 too, but the benefit is not really worth the prize. Since the BS3 there is two subs outputs. Full-range speakers (i.e. Lab 5s) are two bass units. I do not think this is only for large rooms, but because the listening position is more flexible with 2 subs than with only one.
  • 04-30-2009 8:10 AM In reply to
    Emmanuel92:
    Razlaw:
    Emmanuel92:
    SUBWOOFER ON/OFF
    The available settings are as follows under SPEAKER ROLES, one will be listed under the other,  and they both change together when pressing the left/right on the Beo 4. It is not possible for instance to set both to the same position, other than the first option which is SUBWOOFER        SUBWOOFER
    The next option is
    LEFT SUBWOOFER RIGHT SUBWOOFER ,  the next is  RIGHT SUBWOOFER/LEFT SUBWOOFER followed by FRONT SUBWOOFER/REARSUBWOOFER and then FRONT SUBWOOFER/REAR SUBWOOFER and finally REAR SUBWOOFER/FRONT SUBWOOFER.
    Also, when it is set to SUBWOOFER/SUBWOOFER there is only one setting for distance available in the distance menu. If the other options are chosen the distance menu will allow two different distances to be input for each sub.
  • 04-30-2009 8:29 AM In reply to
    Thanks Razlaw for explanation and picture !
    OK, I think I understand how this works. My first supposition seems good: this is related to speaker distances for several subwoofers. SUBWOOFER/SUBWOOFER option is perhaps if you have 2 Lab 2 at equal distance from your listening position (default setup).
    Curious thing is placing a subwoofer at the rear position is not recommended.
    PS: The owner guide has not been upgraded at this time for show these new options.
  • 04-30-2009 8:34 AM In reply to
    Here is another picture.
  • 04-30-2009 8:35 AM In reply to
    Thanks for the replys!
  • 04-30-2009 8:41 AM In reply to
    You're welcome. From your pictures I can see only front and right subwoofer settings.
  • 04-30-2009 7:27 PM In reply to
    Emmanuel92:
    Here are some more pictures. All settings are not available at the same time. They appear when pressing the arrow key on the Beo 4.
  • 04-30-2009 7:31 PM In reply to
    another
  • 04-30-2009 7:32 PM In reply to
    and another
  • 04-30-2009 7:33 PM In reply to
    and one more
  • 04-30-2009 7:34 PM In reply to
    yet another
  • 05-01-2009 8:21 AM In reply to
    There is also one more setting that will display   SUBWOOFER SUBWOOFER. When that option is chosen it is possible to set only one distance whereas with the other settings two different distances can be set. That setting seems to be the normal one subwoofer setting.
  • 05-01-2009 8:23 AM In reply to
    There is also one setting ....SUBWOOFER  SUBWOOFER. With that setting it is only possible to set one distance in the distance menu. It appears to be the normal one subwoofer setting.
