Latest post 04-20-2009 3:32 PM by Sandrikor. 13 replies.
Page 1 of 1 (14 items)
  • 04-19-2009 10:03 PM
    BeoCenter 2 IR Problem
    Well i am a owner of beocenter 2 for about 4 years now. My problem is that none of my remotes are working on it anymore , niether beo 4 nor beo 5 as if it accepts no commands at all .... it works fine without the remotes but not with them ...... Tried unplugging it etc but still no luck ...Any Ideas whats the Deal with this ? before i go to the service department ?
  • 04-20-2009 4:05 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: BeoCenter 2 IR Problem
    do yo have a plasma near by? Strong light shining on the unit? Tried checking that it is in option 1?
  • 04-20-2009 7:50 AM In reply to
    No strong light near by nor plasma xD
  • 04-20-2009 9:27 AM In reply to
    • Dave
    • Posts 2,328
    What option number is it in? (do you know how to check this?)
    (on the beo4) press and hold power off and list together, scroll to find option, press go, and press 1
    Is it in a masterlinked setup, or on it's own?
  • 04-20-2009 1:00 PM In reply to
    its on option 1 already i think  ,  about the connection i used to have it connected to 2 beolabs 3     but now its just connected to a beovision 8 no links etc.....on its own that is
  • 04-20-2009 1:14 PM In reply to
    Well after telling me about the options etc witch i had totaly forgotten , checked the manual and had to press list and . together then list until option?  and then A.option  and option 1 as u said  and then to option 0  ;)  working like a charm now ;) thnx for all the help ;) Really apreciated ;)
  • 04-20-2009 1:17 PM In reply to
    However as it seams option 0  witch is my case the remote wont work but it works on option 1 ?  hmmm     when the beocenter 2 is connected to a Beovision 8 only isnt it option 0 ?  or just my idea ?
  • 04-20-2009 2:48 PM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    If you have speaker connected to BC2 set it to A-OPT 1 (BV8 to V.OPT 1). If no speakers
    are connected set the BC2 to A.OPT 0 (BV8 to V.OPT 2!)
  • 04-20-2009 2:59 PM In reply to
    nope no speakers are connected to the beocenter 2    , its just the beocenter2 and the beovision 8   tried BC2 to A.OPT 0 (BV8 to V.OPT 2!)  but the remote wont work with the beocenter 2 then .... hmmm it only works when beocenter 2  is at A.option 1
  • 04-20-2009 3:01 PM In reply to
    well they work fine if i leave it at  A.option 1 at the beocenter 2and   V.option 1 at the beovision 8  .... should i just leave them at those options ?
  • 04-20-2009 3:15 PM In reply to
    • Gerd
    • Germany
    • Posts 523
    How are they connected? Masterlink yes or no?
  • 04-20-2009 3:22 PM In reply to
    between the tv and the socket unit from the beocenter they are connected with a scart no masterlink
  • 04-20-2009 3:25 PM In reply to
    • Gerd
    • Germany
    • Posts 523
    OK, then leave them at options 1 - 1
  • 04-20-2009 3:32 PM In reply to
    ok dokie ;) Thnx again for the help ^^
