Latest post 04-18-2009 6:20 PM by rayfenwick. 4 replies.
Page 1 of 1 (5 items)
  • 04-18-2009 10:02 AM
    Avant flicker
    Hi guys:
    I have just noticed that when watching Freeview on my '96 Avant yesterday that the screen was ever so slightly flickering, almost like a very, very mild straight ripple effect at the bottom of the screen (when I say ripple effect I mean that the ripple occurs in a straight line from left to right as opposed to in ever increasing circles from a centre point).
    The Freeviw box is not expensive and the scart lead ditto. I haven't done any further tests. However from the information given does it look like my beloved TV is dying? Also, as it sits in a shared living room is it going to di quietly or quite possibly burn out and be a fire hazzard!
    Graham
  • 04-18-2009 10:19 AM In reply to
    Re: Avant flicker
    Hi Graham
    I'd definitely check another source/lead etc before reading last rites to your Avant.  I once was asked about a ripple-type picture problem, to discover it was nothing more than the transformer in the VCR  - the magnetic flux was wobbling the TV picture ever so slightly at the bottom.  I swapped it & the DVD around and all was well....
    It may well be your Avant is poorly, but I'd certainly look at other possibilities first.
    Good luck.
    Ray
    Я люблю Банг и Oлуфсен
  • 04-18-2009 11:47 AM In reply to
    Re: Avant flicker
    Hi Graham1982
    Check yuor connetions(scart?) between your avant and your freewiw box
    old avants have trouble with the picture tube try to bump a little hard on the top of your avnt and see if the picture flickers
    regards
    jan
  • 04-18-2009 5:14 PM In reply to
    Re: Avant flicker
    Hi:
    It appears to not be doing it at the moment so I am going with the cheaper diagnosis that it is the connections.
    Thanks for all your help, I am hoping that it was a false alarm.
    Graham
  • 04-18-2009 6:20 PM In reply to
    Re: Avant flicker
    No worries.  Will keep fingers crossed. (Well, not literally, but YKWIM) Smile
    Ray
