Latest post 04-20-2009 4:23 PM by Blackrix. 11 replies.
Page 1 of 1 (12 items)
  • 04-18-2009 8:26 AM
    Beosystem 2500
    Dag B&O vrienden
    Ik heb een Beosystem 2500 bouwjaar 1991. Deze ziet er nog steeds als nieuw uit en doet het nog perfect.
    Alleen als de deur automatisch opent, dan blijft de motor vaak lopen - schakelt niet af.
    Iemand een idee hoe ik dat kan repareren?
    Ook blijft de laatste tijd het groene ledje branden als het apparaat uit is.
    Nogmaals alles werkt verder prima en ik wil hem graag nog jaren gebruiken.
    Alvast bedankt voor de input
    Hans
    Filed under:
  • 04-18-2009 9:06 AM In reply to
    Re: Beosystem 2500
    Hi
    Rephrase your quistion in english and I will ty to help
    regards
    jan
  • 04-18-2009 12:27 PM In reply to
    Re: Beosystem 2500
    Hi Jan
    My inglish is not that goed
    I have a beosystem 2500 from 1991. It works fine.
    But when the glas dors are opens the motor don't stop. You have to pull out the plug and than it works normal (the doors are closing automatic).
    Is ther somting to clean so that it work normal again?
    Thanks for you input
    Hans
  • 04-18-2009 1:03 PM In reply to
    Re: Beosystem 2500
    Hi Hans
    There are two possibilities you must remove the glass doors be carefull when you do so the  way to remove them are as follows,Set the doors in open state unplug the 2500 then carefully pull the top of the glass door against you then do the same in the bottom of the glass door they are fastened with a metalpiece that fits into a plastic clip clean the glass both outside and inside with what we use for cleaning windows also clean the black plastick piece where the remote sensors are located
    the second possibility is the switch located on the motor pulley that drives the opening and closing of the glass doors but thats inside the 2500 and you have to take the 2500 apart and I don't know your skill's with such things:but try the first solution first
    regards
    jan
  • 04-19-2009 2:39 PM In reply to
    Re: Beosystem 2500
    Thanks Jan
    I dit clean the windows and the sensor, but no improvemend.
    I will open the 2500 next week. My skills are good enough to open it. Off it is good enough to close with all parts in place? We will see this week. Is there a parWhistletikelar part to clean when i open it?
    Thanks in advance fot youre afort
    Hans
  • 04-19-2009 2:50 PM In reply to
    Re: Beosystem 2500
    Hi Hans
    Clean or replace the switch located on the motorpulley that drives the closing and opening of the glass doors its in the left side of the 2500 where the drive motor are located.
    regards
    jan
  • 04-20-2009 7:30 AM In reply to
    Re: Beosystem 2500
    Dat groene LEDje gaat uit als je de radio uit hebt staan en dan op de radio op mute duwt Big Smile
    En dat van die motor is waarschijnlijk de schakelaar van de motor zoals Jan al zei.
  • 04-20-2009 9:19 AM In reply to
    Re: Beosystem 2500
    Hi Beomaster8000
    Please give me that in english
    regards
    jan
  • 04-20-2009 12:59 PM In reply to
    Re: Beosystem 2500
    It worksSmile
    I put on he radio and pusht the mute . The green light dit go out.
    I also cleand the switch on the motor for door movement and on the moment al works fine. And i have no spare parts after rebild.
    Thanks for al the help
  • 04-20-2009 1:16 PM In reply to
    Re: Beosystem 2500
    Hi Hans
    Happy to hear that
    regards
    jan
  • 04-20-2009 2:37 PM In reply to
    Re: Beosystem 2500
    Fijn om te horen dat het werkt Cool
  • 04-20-2009 4:23 PM In reply to
    Re: Beosystem 2500
    Groene ledje geeft overigens "Timer Play" aan.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
