I have a beovision 4 with beosystem 2 to which I am trying to connect a sky HD box along with a mac mini.
The panel setup has been configured to use decoder for the dvi-d connector and av for the vga connector. With this setup I can chose STB (DTV/DVI) on the decoder input (which works fine) but I cannot chose PC(VGA) on the AV input.
If I change the CVBS option for VGA to decoder in the panel setup menu and put DVI-D on AV then the reverse is true - I can set PC(VGA) on decoder but cannot chose STB(DTV/DVI) on AV. The only option relating to DVI is DVD(DVI).
Am I asking to much to use the VGA input as well as the DVI input on the panel? The reference book suggests that it is possible. But then the reference guide also tells me that I can set what button activates the camera inputs and I've never been able to find that menu option!
And before anyone asks I've had the software upgraded to the latest version!
Any suggestions?
Thanks in advance... Warren
