Latest post 04-19-2009 4:18 AM by Neil Sears. 2 replies.
Page 1 of 1 (3 items)
  • 04-17-2009 7:55 PM
    US MX 5000 / BeoMaster 7000 / Sony DVD / Sony DSS / BeoLink 5000 / BeoLink 7000 / BeoLink 1000
    Hi All,
    It's been awhile.
    I am over at my folks house and am trying to get sound from a Sony DVD player (connected via RCA / S-Video to a US MX 5000 and then via a BeoLink cable to the BeoMaster 7000) played thru the speakers connected to a BeoMaster 7000.
    I have the BeoLink 1000 that came with the TV, a BeoLink 5000 as well as the BeoLink 7000 but not a Beo4.
    Pressing CDV on the BeoLink 5000 switches the TV from DSS to DVD but pressing AV then CDV does not switch the sound on the BeoMaster 7000.
    All my User Guides are at my house so I am hoping someone has a guide handy and can help. Set-up code for: DSS thru Antenna A, VCR thru AV1 (SCART) and DVD thru AV2 (RCA /S-Video).
    Thanks a million, Neil
    No matter where you go, there you are.
  • 04-18-2009 7:38 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: US MX 5000 / BeoMaster 7000 / Sony DVD / Sony DSS / BeoLink 5000 / BeoLink 7000 / BeoLink 1000
    I am assuming that you have connected the output from the TV to the AUX input of the Beomaster 7000? If so you need to press "shift" - "radio" to activate the Beomaster to accept the TV input from the AUX socket.
    You may need to press a number after "shift" "radio" to get the sound (it's a while since I had a MX connected to my BM7000). Start with 1 and work your way through until you get the right combination. I used a beolink 1000 BTW.
    Hope this solves your problem.
    Chris.
  • 04-19-2009 4:18 AM In reply to
    Hi Chris,
    Thanks for the reply.
    I have yet to try "Shift" "Radio" but did find success with "Shift" "CD" then "Shift" "Sat" to get audio and video for the DVD or "Shift" "TV" to get audio and video for the TV.
    Neil
