Keith,
I did get the codes from www.remotecentral.com, but I found similar codes across a couple Toshiba examples. Here are two examples, and they is the entire code.
Power: 900A 006D 0000 0001 40BF 12ED
Input: 900A 006D 0000 0001 40BF 14EB
Thanks for the tip on the remote codes not always being correct. Even worse, I also read on that same site that many/some Toshiba TVs can be harmed by receiving the wrong code. Ultimately, if my testing continues successfully, I will have to invest in some type of IR capture device.
Stan
