Latest post 04-17-2009 2:25 AM by Jon611. 7 replies.
Page 1 of 1 (8 items)
  • 04-15-2009 4:32 AM
    • Jon611
    • Not Ranked
    • Joined on 12-25-2007
    • China
    • Posts 6
    My Beosound 6, HELP!!!
    My Beosound 6 varies the colour of Cursor Line automatically, I have ever seen it displayed 4 different colour: green / brown / yellow / blue, but the product advertisement just showing one colour - Green, as well the Guide Book does not tell me anthing about varing of colour of Cursor Line.
    1) Does the Cursor Line of Beosound 6 display only one kind of coulor - Green?
    2) If so, Is my Beosound 6 running wrong?
    Anybody have had same experience like this?
  • 04-15-2009 8:35 AM In reply to
    Re: My Beosound 6, HELP!!!
    I think the Cursor changes colour to indicate the battery status. I never heard it would turn blue though.
    Regards
    Alex
  • 04-15-2009 10:24 PM In reply to
    • Jon611
    • Not Ranked
    • China
    • Posts 6
    Thanks for your message Alex,  the change of colour does not indicate the battery status because it happens occasionally, I just found 3 or 5 times of change within the use period of 5 months, I bought it on 31 October 2008
  • 04-16-2009 2:39 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Take it back to your dealer - it should be under warranty.
    Chris.
  • 04-16-2009 2:52 AM In reply to
    • Jon611
    • Not Ranked
    • China
    • Posts 6
    Yes, I did so, but the dealer have no idea about it and can not give me explanation, I left the product there for examining. 2 days has passed, no result at all.
  • 04-16-2009 6:25 AM In reply to
    • Medogsfat
    • Posts 4,045
    As far as I know dealers are required to either fix your item or if they cannot do so replace it with a new one. The quality of customer service & warranty is one of the reasons you pay a premium for B&O products so don't let them fob you off with excuses.
    Chris.
  • 04-17-2009 2:02 AM In reply to
    • Jon611
    • Not Ranked
    • China
    • Posts 6
    Alex, you are right, a green cursor colour indicates that the music player is fully charged, the colour then changes to orange / yellow shades to indicate the status of the bettery, but I don't know why it would turn blue.
  • 04-17-2009 2:25 AM In reply to
    • Jon611
    • Not Ranked
    • China
    • Posts 6
    Yes, Chris, I agree, I will keep pushing until receive a satisfying result.
    The dealer has checked the unit and found LCD is defective with white dot, this is product defect and covered by B&O's guarantee, the dealer has agreed to repair it by replacing a new LCD, let me see what it'll be when new LCD is fixed.
