Latest post 04-15-2009 6:28 AM by calibano. 4 replies.
Page 1 of 1 (5 items)
  • 04-14-2009 2:47 PM
    • calibano
    • Not Ranked
    • Joined on 05-27-2008
    • london, UK
    • Posts 4
    Beogram 4000 tonearm issue
    hi all, I have a self generated issue with my bg 4000, that is, totally caused by my ineptitude.
    while repositioning the belt, I have mistakenly altered the position of the screw of the aluminium cylinder that only now I understand regulates the arm dropping time. as a result of that (or, so I believe) the arm does not drop at all. before my genius-like intervention, all was ok. can anyone help me?
    thanks,
    leonardo
    Filed under: ,
  • 04-14-2009 5:46 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 4000 tonearm issue
    Leonardo,
    I noticed your PM with the same content. Let's take it in public, others may benefit from what we find out;
    Remove power from the Beogram.
    Can you operate the solenoid, piston and its metal arms by hand ?
    When/if you do, does the arm lift/lower accordingly ?
  • 04-14-2009 6:52 PM In reply to
    • calibano
    • Not Ranked
    • london, UK
    • Posts 4
    hi martin,
    thanks for coming to my rescue,
    it does, a bit forcefully, but then comes immediately back up. clearly, whatever controls the descent is not working.
  • 04-15-2009 3:10 AM In reply to
    • Dillen
    • Posts 5,008
    Is the solenoid (electric coil that activates the arms), doing anything when the arm is supposed to lower ?
    Do you have a voltmeter ?
  • 04-15-2009 6:28 AM In reply to
    • calibano
    • Not Ranked
    • london, UK
    • Posts 4
    I do not, and I'm completely out of my depth here. a guy more knowledgeable than me is coming over to have a look tonight. will keep you guys posted.
    leonardo
