1st March February 2012
Latest post 04-13-2009 8:54 PM by Dillen. 10 replies.
04-13-2009 7:09 AM
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
Beogram 8000 hum and crossover
Hello,
I have just bought an old Beogram 8000 with a nice MMC20CL pickup for the amount of Danish money that is equal to 40 pounds . I have just sent my BG 4002 to repair because of a speed probem. I hooked the 8000 up with a "Tape 1" cable with datalink from my dad's beocord 8004, this is of course inducing some hum, but i get a "cykling" hum when the pickup is on a record. It is like it is humming when it has spinned one turn. The Datalink is not responding on the BG, but the "beep" signal is reaching to the speakers, as if the datalink signal is being amplified. I know that double screened cable is required for proper sound, but this thing is humming rather loud, like it is not being grounded at all. Is there anything I can do for bringing this old beauty back to life? It is only temporary, as my BG 4002 is sent to repair (at a former B&O Tech), and is taking some time, as he no longer is doing it for a living....
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
birgerbum
- Joined on 03-15-2009
- Posts 230
Re: Beogram 8000 hum and crossover
Hej søren
gi mig den lige på dansk
mvh
jan
birgerbum
- Posts 230
Hej Søren
mvh
jan
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Jeg har lige købt en billig Beogram 8000 med MMC20CL pickup. Der fulgte ikke noget Dobbelt skærmet kabel med, så jeg bruger min fars Tape 1 kabel fra en Beocord 8004.
Datalink fungerer ikke, selvom at det brugte kabel har fuld gennemgang i alle ben. Istedet kommer Datalink bib lyd istedet. Når der skruet op på normalt lytteniveau (for mig rimeligt højt) er der en slags brum som kommer efter at pladen har kørt én omgang. Det er lidt svært at forklare... Oveni støjer den sindsygt meget som hvis den slet ikke er jordet. Er der en billig midlertidig løsning, da min primære pladespiller, en Beogram 4002 har et problem med at holde hastigheden, er blevet sendt ind til en tidligere B&O rep.
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Mønsteret på tachoskiven under pladetallerkenen er faldet fra hinanden, så hastigheden aflæses forkert for hver omgang. Jeg har nye repro skiver i rustfri stål.
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Hvad kommer sådan en skive til at koste?
Søren
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Er tacoskiven et rundt stykke metal med riller med en diameter på ca. 8 cm, som sidder ved lejet?
Dillen
- Posts 5,008
Ja, det er den. Den er fremstillet med en fuldstændig sindssyg præcision. Hvis den er i metal i din Beogram (ikke fotografisk fremstillet) og ikke fysisk beskadiget, er den ikke skyld i fejlen. Hvis den er fotografisk fremstillet, er den sandsynligvis årsagen. Du har en besked i din inbox (øverst til højre).
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Har set beskeden, men kan en skive fra en Beogram 8002 sættes på istedet? Min far har nemlig en "Donor" til hans egen 8002, men hvor mange dele er identiske med BG 8000, hvis det er?
Dillen
- Posts 5,008
Skiven passer fra en 8002 (som noget af det eneste) men man hugger da ikke bare en tangential pladespiller af denne karat op for dét, slet ikke en 8002 !
Dillen
- Posts 5,008
Brummen kommer fordi kablet er helt forkert afskærmet til en pladespiller. Tape og Phono kabler er ikke lavet på samme måde. Du skal bruge det rigtige kabel.
Page 1 of 1 (11 items)
