Latest post 06-03-2007 1:26 PM by Santiago. 27 replies.
Page 2 of 2 (28 items) < Previous 1 2
  • 06-03-2007 11:07 AM In reply to
    Re: BL3s flu
    Henry:
    Oh, I meant to ask you before, have your BL3s just cut out / stopped playing at any stage? This is what happened to my right channel BL3 and it was then that I noticed the yellow LED from memory.
    No Henry, BL3s have not stopped playing at any moment, their sound is just perfect, and leds are both always green.
    Santiago
  • 06-03-2007 11:57 AM In reply to
    Re: BL3s flu
    Santiago,
    I felt your problem was likely to re-occur because we did not actually track down the cause.
    Based on the information Henry supplied I feel he had a very different fault which was clearly a faulty speaker.
    In my view your situation is very different and I think we need to recap where we are fault finding the problem, so lets restate the facts as I have understood them:-
    1) The pair of Beolab 3's are brand new and all supplied cables are used.
    2) Both speakers are both exactly the same high temperature after about one hour.
    3) The Beolab 3's took the place of Beolab 4's which had been working perfectly.
    4) When running the Beolab 3's for several hours in the bedroom, they remained totally cold.
    5) Your home is about 6 years old and never had any power related issues before.
    If I have understood everything you have said correctly, then I still feel you have a power or earthing related problem.
    If your dealer does decide to replace the Beolab 3's, I feel those new speakers will still get hot unless you were very unlucky and had two faulty speakers with the same problem, possibly caused if it were a manufacturing issue. One way you could be sure if you have a power/earthing issue is get a one-to-one mains isolating transformer and power the speaker via this isolating transformer. If your speakers still get hot, then the problem is almost certainly two faulty speakers with the same problem. If, however the speakers remain cold in use then you know for certain that you have a power/earthing issue in your home.
    Regards Keith....
  • 06-03-2007 1:26 PM In reply to
    Re: BL3s flu
    Keith Saunders:
    Everything correct.
    but in fact I've only tried 4) once...so maybe not a definitive test.
    and
    6) Never had a heating problem with any beolab (BL1s,BL2,BL6000s,BL4s) or any other beo-device (Avant,BS9000,HDR2,LC2,BC6000...) all over the apartment Confused ...weird.
    7) BL3s are now plugged in the place of BL6000s which never had a heat problem.
    I can imagine if I have a power/earthing issue in my home, at least one of them could get hot sometime...Confused but only happen with these BL3s.
    Santiago
