Hi guys,
I would like to remove the display covers on my Penta IIs in order to clean them on the inside. Is there any easy way to do this?
Thanks,
Aaron
Just pull on the side like shown in the picture below
ducha: Hi guys, I would like to remove the display covers on my Penta IIs in order to clean them on the inside. Is there any easy way to do this? Thanks, Aaron
Beware - They are brittle with age - and no longer available!!
Regards Graham
Okay, thanks for the response Gerd and thank you for the warning Graham!
