Latest post 04-13-2009 2:10 PM by Gerd. 3 replies.
Page 1 of 1 (4 items)
  • 04-12-2009 3:55 PM
    Beovision 3-28 master link option 6 problem
    Hi all, I have a beovision 3 -28 that seems to be stuck on option 1, I need to use it in a linked system but I can't get it to go to option 6 using a beo 4 OPTION, V-OPTION then pressing 6. The unit has a masterlink socket could it be the link connection is not enabled, can anyone assist please. Thanks Terry
  • 04-13-2009 3:06 AM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Re: Beovision 3-28 master link option 6 problem
    The masterlink socket is always present but the module isn't.
    This was optional on your BV3-28. It is still available with order-nr.  1401500
  • 04-13-2009 1:58 PM In reply to
    Thanks - any idea of the cost?
  • 04-13-2009 2:10 PM In reply to
    • Gerd
    • Germany
    • Posts 523
    Approx. 215 EUR here in Germany.
    BTW: you just need to remove the back cover and plug it in.
