Latest post 04-17-2009 3:14 AM by Keith Saunders. 2 replies.
Page 1 of 1 (3 items)
  • 04-10-2009 5:55 PM
    • Michael
    • Top 200 Contributor
    • Joined on 05-23-2007
    • Atlanta, USA
    • Posts 318
    I know its pretty much just for show but is it currently possible to program icons 2x2 in the style as the masterlink gateway demonstration on B&O's website?
    -Michael
  • 04-16-2009 5:47 PM In reply to
    • Michael
    • Atlanta, USA
    • Posts 318
    Re: Masterlink gateway icons
    Anyone??? I'm just simply asking if there is an ability now of doing 2x2 icons instead of just 3x3 & 4x3 with the newer software......I know, I know...You guys are just punishing me out of jealousy for snagging the coolest avatar before you had a chance too;)
    -Michael
  • 04-17-2009 3:14 AM In reply to
    The answer to your question is YES & NO
    The reason for the mixed answer is the screen itself being a LCD screen means it can display any size form in principle, however the Configuration Tool limits the size which can be displayed, but what you are discribing can in principle be done and I am aware of at least one member who has done it with an earlier versions of the Configuration Tool which did not enforce the size restriction.
    Regards Keith....
