you'll have to elaborate a bit for me Martin
I understand its a mono microphone...only two pins used...BUT i have 2 MD8s at the moment and the Din plugs are wired differently!! Is the middle pin the dud one? Also why are there two wires, red and black, doesn't it matter which way they go? What function do each of the two wires serve since its mono? There aren't any manuals at the moment on Beoworld.
Think I'm going to feel very dumb after this is explained!!!
