Latest post 04-11-2009 5:08 AM by gk31ax. 4 replies.
Page 1 of 1 (5 items)
  • 04-10-2009 3:07 PM
    Hard Drive Advice
    I'm wanting to store all my music and DVD's on an external hard drive and play them back on a BV8 using Beo 4. Is this possible? I'd also like the hard drive hidden away in a cupboard out of sight.
    Any suggestions?
  • 04-10-2009 3:49 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: Hard Drive Advice
    Well,
    BeoMaster 5 leaps readily to mind, naturally.  But I might also mention AppleTV.  Both will work as described.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 04-10-2009 5:21 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    The BeoMaster 5 isn't a media centre so won't do DVDs/video playback (it supports video playback, but it's more for short family snaps etc...
    You may want to have a look at the TViX system, or on more of a budget, something like the Apple TV.
     Weekly top artists:
  • 04-10-2009 11:32 PM In reply to
    I bought a "Ready NAS" Duo from netgear. I have an Apple TV running Boxee accessing that through my wireless network. My BV8 with BV4 controls that. The Readynas is mirrored 1 TB drive so I have a high level of fault protection.
    I think you can connect other drives to the ATV as well ....... You could also use a Mac Mini, that should actually work a bit better since the ATV is a bit undersized for some applications, i.e. Netflix or Hulu streaming.
    Cheers
    JK
  • 04-11-2009 5:08 AM In reply to
    I'm using a mac-mini as my media hub, you'd also need an external hard drive unless you have a small library, works a treat......
