Latest post 04-14-2009 2:07 PM by diggs2701. 2 replies.
Page 1 of 1 (3 items)
  • 04-10-2009 1:13 PM
    Beo5 and Kodak Digital Photo Frame
    Just wondering if anyone had any luck with configuring the beo5 with a kodak digital photo frame?
    Diggs
  • 04-14-2009 8:25 AM In reply to
    Re: Beo5 and Kodak Digital Photo Frame
    Diggs,
    To control any third party product with the Beo5 where there is no XML configuration previously produced requires you to either know the 3rd party protocol being used and its associated commands or have the original remote and capture the commands to convert into an XML control file.
    If you have the original remote control for ANY third party product and have a means of capturing the infra-red signals such as using a Lintronic box or similar, then a XML file can be produced for that product.
    Do you have the original remote for the Kodak digital photo frame ? if so, do you have a means of capturing the commands ?
    Regards Keith....
  • 04-14-2009 2:07 PM In reply to
    I have the remote but I am not sure if I have anyway to capture the commands. What do I need to capture the commands? Thank you for all of your help!
    Diggs
