Latest post 04-24-2009 3:59 AM by Perry Waring. 8 replies.
Page 1 of 1 (9 items)
  • 04-10-2009 10:43 AM
    BeoMaster 4500 Glass
    I am thinking of buying a broken BeoMaster 4500 - the Glass has fallen off & broken. Reading on here I believe the glass is no longer available as a spare, would it be possible to have a piece of glass cut to fit or is there more to it than that.
    Your help would be appreciated
    thanks
    Perry
  • 04-10-2009 12:53 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: BeoMaster 4500 Glass
    Hi Perry, and welcome to Beoworld. It is a lot more than getting the right size piece of glass. One of the problems is there is a special coating on the back of the glass which makes it touch sensitive. Also the glass has the functions printed onto it too.
    CraigSmile
  • 04-10-2009 2:00 PM In reply to
    Thanks Craig - thought that may be the case, looks like i need to buy  another unit with a good glass
    PerrySad
  • 04-13-2009 11:04 AM In reply to
    you might actually want to try your b&o dealer and see if they can still order a NOS piece from inventory. i got lucky w/ the same part for a 9300, granted it was newer...
    • B&o bottle opener
  • 04-13-2009 1:24 PM In reply to
    pez01:
    PerrySad
    You would be better off buying a cosmetically challenged Beomaster 3500 as the glass is identical.
    Regards Graham
  • 04-14-2009 4:23 PM In reply to
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Not much irritates me about B&O ever except this!!! I know this has been spoken about many times and that B&O can't be expected to keeps parts forever BUT in this case I feel that the reason that glass panels need replacing is entirely B&O's fault. People have paid good money for these systems and now end up with units that are only good for parts or the trash. Its B&O's fault that the panels are falling off as they did not use a proper method in fixing the panels to the plastic holders. Lets also not forget that a huge selling point for the 3500/4500systems was that the cd player also could be wall mounted, so B&O in a way encourage buyers to have their systems wall mounted. Now that they panels are falling off to do bad production methods, B&O just turn a blind eye. I don't think its right. They should still carry the replacement panels. If it was just because people were breaking them, that would be another story. I really feel like writing to B&O but its doubtful they would take any notice. Its a very bad reflection on a B&O to not take responsibility for something that is clearly their fault. I was lucky enough to buy a get a glass replacement for my BM but should I ever need another one because it just happened to fall off, I would hound B&O constantly about till they found one for me.
    Durban South Africa
  • 04-15-2009 3:40 AM In reply to
    I agree about it being B&O's fault. I did mail B&O once about it but just got the standard reply saying "Sorry contact you dealer etc etc" (seems to be a standard reply for every mail). Al remains silent when I mail them saying my dealer no longer exist where I bought my 4500.
    Over the years I have collected several broken 4500 and 3500 components to use as spares. I have fitted a 3500 glas pabel to a 4500 and I can confirm it works even though the plug on the end of the cable can be slightly different, but with a bit of force it wil fit.
  • 04-15-2009 3:51 AM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Well I will write to them and see if I get a response. There is no doubt that it is an error on B&O's part. I don't think it will be such a major thing for them to produce the panels and make sure that they don't come loose.
    Durban South Africa
  • 04-24-2009 3:59 AM In reply to
    Thanks guys for caring - I'm on the look out for a broken unit with a good glass so if you hear of one let me know - PerrySmile
    Filed under:
