Latest post 04-08-2009 8:13 AM by Razlaw. 2 replies.
Page 1 of 1 (3 items)
  • 04-07-2009 7:18 PM
    Beo 5 question
    Sorry to ask what is probably a very basic question. We have a PC connected via Master Link with iTunes. To operate it I press N. MUSIC and then STOP and then use an iTouch to control iTunes. Is it possible to program the Beo 5 so that with the press of one button it will activate N. Music as well as Stop?
    Similiarly we also have Apple TV connected. We use V. Mem to activate and then I control it with the Beo 4. However, because it is a video source all five speakers turn on and I must use the Speaker function of the Beo 4 to switch to 2 speakers. Would it be possible to program a Beo 5 so that one press of a button would activate the V. Mem input as well as switching to 2 speakers?
    Thanks.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 04-08-2009 2:23 AM In reply to
    Re: Beo 5 question
    The answer to your question is YES you can.
    You can assign a macro of commands to a single button or command
    Regards Keith....
  • 04-08-2009 8:13 AM In reply to
    Re: Beo 5 question
    Thanks!
